I want to lower the spider when it gets on the road.
Ive ordered Competizione 15x7's and 195 50 15's for the car.
Anyone running this set up? Anyone with pics of before and after?
Best Springs for lowering?
Lowering the Spider
- Your car is a: 1972 Fiat Spider 124
Re: Lowering the Spider
I have 205/50-15's on mine and I believe the overall diameter is close to the original 13 inch wheels. Where I got the lowering was switching out the KYB's to Koni yellows and I have un-altered IAP reds for springs. Some chop springs to lower, tried that, didn't like the ride and fit. I believe the vendors here offer a progressive spring. But as mentioned the Koni's made the difference in lowering the stance. With the 1" front sway bar as well the handling is terrific ...for a 37 year old car.
195/50 15 are stock tire size for my car.
Jim
Jim
- azruss
195/55/15 will match the original tire OD the best. This will minimize speedo error.
But I believe that still depends on the brand. Tires can be all the same size but have significantly different rolling circumferences.azruss wrote:195/55/15 will match the original tire OD the best. This will minimize speedo error.
Jim
I don't believe that's the case...the #'s are the #'s. In the example above, 195mm is the width, 55% of the width of the sidewall height, 15" hole diameter (specifies rim size).Jimb wrote:But I believe that still depends on the brand. Tires can be all the same size but have significantly different rolling circumferences.azruss wrote:195/55/15 will match the original tire OD the best. This will minimize speedo error.
Jim
Here's a great tool that lets you put in two tire sizes and shows you visual comparisons of size. You enter your stock size (OEM) and the tire you're looking at and it'll give you actual speed comps at 10, 20, 30 etc up to 90 mph. Your 195/55/15 is almost identical to the stock 165/80/13's. Speeds up to 90mph are spot on, though in one mile the stock tire will make 886 revolutions and the 15" tire will make 888. 2 revolutions per mile...the odomoeter will be just about dead on at 1 milliion miles
Here's the link to my favorite tool:
https://tiresize.com/calculator/
It's my understanding that tires vary in their Treadmill, Traction, and Temperature ratings....and these affect the rolling circumference, which in turn affects the speedometer.
Difference tires react differently to heat and cold...in some cases quite substantially. For example my Tacoma pickup has new tires that are the exact same size as original spec but different manufacturer. The speedometer now shows I'm going about 4 klm/hour faster at 90 than with original tires.
Jim
Jim
I THINK Jimb is right. My 35's on my jeep are more like 34's, but the Tires before measured 35's on the dot. I guess it wont matter any way, I ordered 195 50's and theres no looking back!Jimb wrote:It's my understanding that tires vary in their Treadmill, Traction, and Temperature ratings....and these affect the rolling circumference, which in turn affects the speedometer.
Jim
Jimb, your car has a great stance! Cant wait to show mine off!
- azruss
Tires do vary. They also change diameter depending on wear, speed, etc. If you go the the tirerack webpage, the give information on tire diameter of various brands and sizes. I used this to calculate what size i needed for 195s. I decided to not go with 205s because I didn't want to give the car a heavier feel than I was already giving it. The 195s definitely give the car a rougher ride than stock. I actually dropped by tire pressure a couple of pounds to help compensate. Running 30 psi in front and 28 in back. Last time i checked the tires it had gone down to 28 in front and 26 in back and still drove great.
