I have an 85 and am wanting to remove the rather large combo switch bezel that contains the power window switch, hazard, trunk release and a couple of other lights that don't seem to work. I don't know if anyone would know the answer to this, but will ask anyway. Is there an aftermarket power window and hazard switch that can be used? Could I use something like this for the window switches?
http://www.summitracing.com/parts/spu-i ... /overview/
Thanks for the help.
Aftermarket PW switch
- Your car is a: 1985 Spider
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
1985 Pininfarina
2011 Eos
- 124JOE
Re: Aftermarket PW switch
they may just have a short in the ground wire
these cars are known for bad grounds all over
The lights that don't work are just some type of warning lights. I can do without them. I'm just looking for an alternative to my power window switch and hazard switch.124JOE wrote:they may just have a short in the ground wire
Don Avery
1985 Pininfarina
2011 Eos
1985 Pininfarina
2011 Eos
- 124JOE
looks like you need to spend a day in a junkyard
$15 and three hours so you can bring home just what you want
