Any idea what these are?
- jfrawley
- Your car is a: 1982 Spider
Found them in my 1982 Spider. PO didn't know what they were for. Anybody?
http://s303.photobucket.com/albums/nn12 ... ese001.jpg
- perthling
Re: Any idea what these are?
Look like the catches for the quarter windows. Round flat part is glued to the glass, angled piece rotates around round piece and locks window closed against window frame.
_______________________
Perthling
1974 Fiat 124 Spider (blade bumper 1756cc)
1974 Fiat 124 CC (same family since new)
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
1997 Coupe Fiat 20VT (daily driver)
http://www.fiatlancia.org.au
Perthling
They look like some type of vent window latch but not for a Spider.
We posted at the same time! I wondered why a different message came up when I hit 'submit".
Those are the window catches for an 80 or later Spider. I dont know what earlier models used them.
- jfrawley
Well that solves that. Thanks.
They changed the design? Do they stay on better?
- jfrawley
I found mine in the glove box, so I guess not.
you will find that Fiat did indeed change the style. at our garage, the '78 is the old fashioned kind where you had to depress a button to unlock the latch before turning. I think that is the style you are thinking of Denise.
The '80 has the style shown in the picture on this post.
They do NOT stay on any better, still being glued in place. I have glued the passenger side on my '80 so many times i have lost count. It resides in the glovebox now, on a more-0-less semi permanent basis.
- ga.spyder
I was gonna ask if anyone knew of a glue that would keep them on...apparently not.I tried twice with mine ,which now live in my parts box.
Craig
Craig
Craig Nelson
Fling It Around Turns !
Mine have never come off since new. I open the window almost every time I drive the car and flip the windows all the way open. I think you might have to use a different brand of adhesive. I think Permatex makes a professional one. Are you guys using the little triangle shaped glue that is found in every store? Surface must be perfectly clean and oil free, with all old residue carefully scraped off. Better bet is the auto glass stores. I think they have a glue that is UV light activated (purple light) and should not be too expensive for them to do it.
I assume y'all are using Rearview Mirror adhesive. That's what I used on my BMW, and it worked great. BTW, bmw 2002s use the same window latches as the early (pre-'80?) spiders and coupes.
I'm assuming you guys have tried mirror base adhesive, correctly applied. It does need to cure for a few days to get to full adhesion.
Also, considering who is posting here, this is not aimed at you Craig or Mike, but I've seen people pull the wing window shut with the latch, this is how I believe any of these come loose. A PO used it as a pull. The window needs to be pushed shut from the outside, then latched, to keep this from happening.
- Tappy
someone told me to duck tape the latches , however the duck spoiled the view a bit ....
FineItalianAutomobile Technology
