Fuel filler hose
Discuss everything about the "new" 124 Spider here! The good, bad and ugly, anything goes. But keep it clean please!
tblanck
Your car is a: 1978 Fiat Spider
Fuel filler hose
Post by tblanck »
I have a 78 Spyder. The fuel filler neck hose split and I lost a tank of gas. Has anyone replaced this hose? Do you go in from the top or from the bottom or both? ANy hints? Thanks, Tom
Re: Fuel filler hose
Post by AriK »
You can access the hose from underneath. There is a shield to remove and it helps if you don't have gorilla hands.
Funcar
Your car is a: 1972 Fiat Spider 124
Post by Funcar »
Make sure you get the right length. Use the old one to measure. I used a little lubricant that doesn't deteriorate rubber to help slip it on.
Glen
Kitchener ON Canada
73 Fiat Spider 124
