more front light options
I've gotten headlamps with led lights on each side, with separate circuits so that one can act as a park lamp, the other as a turn signal. The headlamp uses an H4 bulb.
The headlamp bucket needs slight modification to accomodate the lamp.
RoyBatty
Your car is a: 1975 124 Spider - 1971 124 Sport Coupe
Re: more front light options
Post by RoyBatty »
Hi Mark,
Can you source this style of lamp in the correct size for a 124 Coupe? :D
georgeramos
Your car is a: 1971 124 Spider 1608
Post by georgeramos »
ooooooooh, I like it, im interested too Mark
it's only available in 7" at this time
amawds
Post by amawds »
I've had those lights on my car for a while wired to the park lights. They have turned into a signature thing for my car, so the one I'm building will have something similar. However, they are NOT bright enough to function as your only front turn signals, especially with the headlights on. I'd advise anyone looking for turn signal options to use at minimum an 1157 style bulb and avoid LED's due to their terrible performance at an angle and in direct sunlight. This is a safety issue.
That said, these lights are fantastic upgrades, the ones I have, have a little "vent" thing at the top that's supposed to seal the headlight, but allow moisture to escape if any makes it in as an anti-fog measure. To say the least, this works extremely well and I've literally never seen the inside of the housing fog up even after a couple weeks of sitting, or only driving with the park lights on for extended periods of time. I purchased them elsewhere though, so no guarantee that they are the same. However they look identical and have the same number of LED's.
rbp911
Post by rbp911 »
I would like to add a set of fog lights to the front of my 1985 Spider but I don't see a good place to mount them.
Does anyone know where to0 get a light bar and how it should be attached?
spiderrey
Post by spiderrey »
Ive got some cool lights for a coupe in my garage.
toplessexpat
Your car is a: 1976 Spider 1800
Post by toplessexpat »
On the Spider... I've just removed by 4.5" spot lights (which are now winging their way to the UK), and replaced with a 17" LED 108W bar attached to the cross member that's in front of the radiator. Works really very well, and is (fairly) discrete as it's behind the lower grill.
The road close to the car gets flood light by the center section well, and the outer 1/6 on each side has more of a spot lamp effect.
Many classic Fiats - it's a disease!
www.mirafiori.com
rbp911
Post by rbp911 »
SPIDERREY
IS YOUR POST A RESPONSE TO MINE CONCERNING FOG LIGHTS AND A MOUNTING BAR. IF SO, COULD YOU PROVIDE MORE INFORMATION? MY EMAIL IF YOU WANT TO SEND PICTURES IS RBP911@GMAIL.COM.
rbp911
Post by rbp911 »
TOPLESSEXPAT
COULD YOU PROVIDE MORE INFORMATION ABOUT THE MOUNTING BAR? WHERE TO GET ONE SO I CAN GET IN CONTACT WITH THE VENDOR FOR LITERATURE WOULD BE HELPFUL.
RON
toplessexpat
PM sent
www.mirafiori.com
rbp911
Post by rbp911 »
TOPLESSEXPAT,
I HAVE AN AIR CONDITIONING CONDENSER IN FRONT OF MY RADIATOR SO THAT THE CROSS MEMBER IS NOT ACCESSIBLE.
I HAVE SEEN CHROME LIGHT MOUNTING BARS ON THE FRONT OF FIAT 2000'S IN PICTURES, JUST CAN'T REMEMBER WHERE
I SAW THEM. IF ANYONE ELSE OUT THERE HAS ANY INFORMATION IT WOULD BE APPRECIATED.
RON
amawds
Post by amawds »
rbp911, welcome to fiatspider.com. You'll have fun here. But please turn off caps lock :wink:
4uall
Post by 4uall »
Too much yelling ? LOL
toplessexpat
rbp911 wrote:TOPLESSEXPAT,
I HAVE AN AIR
(truncating to protect my ears :))
Not sure where you have your air conditioning unit mounted. The 17" bar is hanging in the lower grill - not the upper....
www.mirafiori.com
