Under Cowl Washer Bottle
Post by RRoller123 »
Would someone post a picture or two showing the windshield washer bottle system that is used on the late model Spiders and sits under the cowl? For a number of reasons, I want to convert to this approach, but have never seen it. I assume that I can get the bottle here on the forum or from one of our vendors and it should be a fairly simple conversion.
Thanks!
Pete
wizard124
Re: Under Cowl Washer Bottle
Post by wizard124 »
Pete:
Mine was missing so I had to buy one from salvage. Sits in the front left:
It has a bracket that attaches to the top of the crossmember which runs in front of the radiator. That crossmember has a small square cutout. I used a plastic insert and a sheet metal screw to secure the bottle bracket to the crossmember. I don't know what the original set up is. If you look carefully, you can see the cutout just below the bracket in the picture above.
I also took these 2 pics of an installed bottle. I think this bottle is different than the one I bought. Mine does not attach at the radiator but does attach to the side of the charcoal canister:
As it turns out, mine leaks :x I haven't removed it to see where. The pump works!
Warren
Thanks but this is the system that I currently have and now can't use, due to mods, etc. The later (I think 82 and on) used a system where the bottle was under the windshield cowling, and that is what I need a pic of. But thanks anyway, for going through the effort! I am tempted to put the existing bottle in the trunk and run a line up front.
This is the system that I am looking at. It has this bottle mounted somehow under the front windshield cowl I believe. Can anyone describe in detail or show a pic of how it is installed? Thanks!
http://www.midwest-bayless.com/storefro ... =317807227
bradartigue
Post by bradartigue »
RRoller123 wrote:This is the system that I am looking at. It has this bottle mounted somehow under the front windshield cowl I believe. Can anyone describe in detail or show a pic of how it is installed? Thanks!
They fit exactly one way, under the cowling. Hard to describe otherwise, the thing is molded to fit the cowling. I have no idea if pininfarina changed the cowling to fit the bottle, it is unlikely they did. Once you figure out the position you'll need to cut a hole for the cap.
Better option: get the rubber bag type with a new pump. They work very well and are easy to relocate to other places in the engine bay or wherever.
Under cowl bottle received this past week and will be installed. Got a great one from John at spiderparts. Thanks, John! I will post some pics when I get it done, hopefully before Tutto next Sunday.
