Radiator Hoses With Coils - Specifically Lower
jimmycakes401
Post by jimmycakes401 »
So, if you're read my threads you know my lower coolant hoses collapsed. I'm trying to get to the bottom of it, but since my hoses tore, I'll need to replace them. Currently they are back ordered at most of the main sites. I wouldn't mind replacing my lower with the coiled type that won't collapse. Does anyone have a source that will fit a spider? Can I even cut them to length? I did find this site, but I would hate to order them to find out they don't fit right. 26" is definitely too long.
http://www.rockauto.com/catalog/moreinf ... cc=1104512
4uall
Re: Radiator Hoses With Coils - Specifically Lower
Post by 4uall »
this might help :wink:
http://www.fiatspider.com/f08/viewtopic ... 17&t=13530
GOOGLE IS YOUR FRIEND :mrgreen:
jimmycakes401
I've seen that, but I was thinking more along the lines of the rubber ribbed variety. Cheaper and achieves the same result. I just wonder if you can cut the rubber ones and clamp them on or if you have to buy that exact length so you have the cuffs.
jimmycakes401
The rubber one I posted above is like $8... and is supposedly for a 124, but seems way too long.
toplessexpat
Your car is a: 1976 Spider 1800
Post by toplessexpat »
Many classic Fiats - it's a disease!
www.mirafiori.com
4uall
Post by 4uall »
I am sure you will be fine :wink: any of the big box stores should have what you need or cut to measure 8)
jimmycakes401
Topless: Too pricey. I have other things that need the $$ like my rear shocks that need repalcing.
4Uall: Thanks man. Didn't think they sold the flex hose there. I'll check it out. I also saw some springs that I could buy OEM style and shove in the standard hoses, but since that bottom one is tough to find right now, I'd like a "quick fix" just to get her back on the road.
kgfiske
Your car is a: 1978 Fiat Spider
Post by kgfiske »
If you look a bit closer on the Rock Auto site, they list a Dayco 81041 flex hose which measures 1-1/4" ID x 14 3/4" long. That ought to work fine. If you want a shorter hose 13" long, go with a Gates 25251 also sold on the same site.
Kelly Fiske
Shepherdsville, KY
78 Spider
jimmycakes401
Thanks KG! Will check that out.
