The primary cause of the problem is the carburetor float bowl emptying when the car sits for any length of time.
1. Ensure that the diaphragms for the accelerator pump (part 85 in the image below), power valve (part 15 in the image below) and auxiliary valve (part 20 in the image below) are not leaking. A leak in any of these will cause the float bowl to empty after the car sits for a while.
- Leaks in the accelerator pump diaphragm are obvious. You will see it leaking when the car is running - especially when you rev up the motor and activate the accelerator pump. The diaphragm is available through just about any parts supplier.
- A leak in the auxiliary pump diaphragm will result in fuel being pulled through the diaphragm into the vacuum line that leads to the auxiliary pump (part number 11 in the linked image). You will not see an external leak if this is happening. If the gasket (outer part) of the diaphragm is leaking, you may or may not see a visible leak. Look for fuel residue on the intake manifold beneath the auxiliary pump to determine if there is an external leak. This diaphragm is no longer available. You'll have to find a good used one. Chris Obert had them recently, but I don't see them on his site any longer. If it is a leak in the gasket part of the diaphragm, you can use a fuel resistant sealant to stop the leak so the float bowl won't empty out. Use a non-hardening fuel resistant sealant designed for this purpose. Use it very sparingly.
- The other possible source of a leak is the power valve diaphragm. Leak symptoms are similar to the auxiliary valve diaphragm. Last I saw, the only vendor who has this part is Midwest-Bayless.
2. Also check the orientation of the auxiliary pump vacuum line. It should point up not down. See the image for reference.
Also look to see if your fuel supply check valve located under the hood is functioning. It should not let fuel bleed back out of your fuel filter and into the gas tank. This will not affect fuel levels in the float bowl. The part is available from Midwest Bayless.http://marketplaceadvisor.channeladviso ... =261868029
While working on the fuel system, consider the following: Replace the fuel vapor check valve located beneath the car near the fuel tank. If you unscrew your gas cap and there is built up air pressure, the valve is bad. This check valve permits built up pressure in the tank to flow to the vapor canister but not in the other direction. This won't cause the starting problem but it can cause your filler pipe hose to burst if too much pressure builds up.
http://marketplaceadvisor.channeladviso ... =251937197
Hope this helps!
