'77 firewall cracked from clutch
Rupesy
Your car is a: 1977 Spider
Post by Rupesy »
I see this is a common issue. I was wondering if someone had any pics of how they fixed it? Just looking for some ideas. I am going to fix it myself. I have seen a couple posts, but nothing with the final fix.
Thanks.
'77 Fiat Spider
'79 Porsche 928
'83 Jeep CJ7
'04 Chevy Suburban
'04 BMW Z4
'00 Porsche Boxster
bobplyler
Patron 2022
Patron 2022
Re: '77 firewall cracked from clutch
Post by bobplyler »
I drilled a hole in an old motorcycle tire iron, and siliconed it to the firewall.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
narfire
Post by narfire »
Take the brake booster and MC out/off.
I had a parts car and cut the same piece from the fire wall. A piece of sheet steel a couple of mm thick with the hole cut out would work. I then pop riveted it into position over the straightened cracked fire wall. Then with a WET rag below and on the inside, I welded the covering piece to the fire wall.
Worked great. took about 3-4 hours to do.
Chris
divace73
Post by divace73 »
bobplyler wrote:I drilled a hole in an old motorcycle tire iron, and siliconed it to the firewall.
I'd like to see that.
Cheers David
see my >>You tube channel<<
SoFlaFiat
Post by SoFlaFiat »
Me too!!
bobplyler
Patron 2022
Patron 2022
Post by bobplyler »
I since had it repaired correctly. That was about 20 years ago. And I had no other car at the time, so had to improvise one night.
azruss
Post by azruss »
If you are concerned about heat damage, you may want to epoxy the new plate to the firewall.
SoFlaFiat
Post by SoFlaFiat »
How's it go?
Ingenuity is the mother of all invention!!
fredguaz
Your car is a: 1977 Fiat Spider
Post by fredguaz »
I think it's, "Necessity is the Mother of all invention."
Fred
Lake Norman, NC
1977 Fiat Spider (current project)
1977 Triumph Bonneville 750 (previous project)
1971 Honda CT-70 K0
1972 Honda CT-70 K1
1990 GMC S-15 Jimmy (Daily driver)
