http://2.bp.blogspot.com/-3lhQMEbAWSA/U ... C_0006.JPG
Missing stud near shifter socket
- V12StealthHunter
- Your car is a: 1971 Fiat 124 Spider
I've got a bit of an oily mess near the shift socket cover. I was going to remove the cover and put some sealant on it. Then noticed I'm missing a stud? near the top right hand side of this photo. That looks a little scary. Is that somewhere in the gearbox now?
1971 Fiat 124 Sport Spider
- Patron 2019
Re: Missing stud near shifter socket
I am guessing not as that's in the shifter area vs the gearbox and likely came out with the nut still on it. Can you tell if the stud is just missing or snapped off?
Do you have the boot off the shifter? Maybe someone else could confirm this, but I think that's the reverse lockout stud that is missing which prevents your from accidently going into reverse when shifting down from third to fourth gear.
BTW, if you reduced the image pixel size to something like 800x600 I think the whole image will be viewable in your thread and you won't need the hyperlink.
Current 81 Spider 2000
Previous 76 Spider
Previous 76 Spider
- FiatMac
That is correct. The stud has an extension into the interior of the shifter housing mates up with a tab on the gearshift lever that prevents going to reverse unless you push down on the gearshift lever. This prevents accidental shifts into reverse.76was124 wrote: Maybe someone else could confirm this, but I think that's the reverse lockout stud that is missing which prevents your from accidently going into reverse when shifting down from third to fourth gear.
Stan McConnell
Retired Mechanical Engineer
Salisbury, North Carolina
82 2000 Spider (driving)
78 124 Spider on the rotisserie
76 124 Spider parts car or possible Lemons racer
83 parts car
83 parts car
- V12StealthHunter
Good to know. I found that spiderroadster.com has the part;
http://www.spiderroadster.com/124shift1.htm
Can that just be threaded back in from below with the gear lever in neutral? Or do I need to remove the shift lever first to get it aligned somehow?
Code: Select all
18 4148579 REVERSE LOCKOUT PIN $16.33
19 10791021 NUT $1.09
- Patron 2019
You would be okay in neutral, but I would put it in 2nd gear (its a little safer if you are under the carV12StealthHunter wrote: Can that just be threaded back in from below with the gear lever in neutral? Or do I need to remove the shift lever first to get it aligned somehow?
The shifter has a square tab that jets out and hits the stud to prevent going into reverse unless you depress the shaft at the same time. Depressing the shaft allows the tab to pass under the stud to get it shifted into reverse.
Previous 76 Spider
Previous 76 Spider
- V12StealthHunter
Thanks a lot. Good to know. I have a feeling my shifter needs to be pulled up? But I could be wrong. I just felt it had a springy action when I pulled it up but nothing when I tried to push it down.
EDIT: Does any one know the thread size for the lock out pin? Or if you've removed yours, can I have it? Thanks.
- Patron 2019
That's sounds backwards? It's probably worth taking it apart seeing how you were missing the bolt, the previous owner may have had it apart too and put it together wrong. The other possibility is the retainer nut on the shifter shaft is loose, which is known to happen. You get to it by removing the cover plate with the three screw from underneath the car. It is directly below the shifter. You can see it in your picture.V12StealthHunter wrote:Thanks a lot. Good to know. I have a feeling my shifter needs to be pulled up? But I could be wrong. I just felt it had a springy action when I pulled it up but nothing when I tried to push it down.
Previous 76 Spider
Previous 76 Spider
- FiatMac
I missed that you had an early car. The early spider transmission did require that you pull up on the gearshift to get into reverse I believe. Not sure what year the change was made to push down.V12StealthHunter wrote:Thanks a lot. Good to know. I have a feeling my shifter needs to be pulled up? But I could be wrong. I just felt it had a springy action when I pulled it up but nothing when I tried to push it down.
Stan McConnell
83 parts car
83 parts car
- Patron 2019
I missed that too! And just learned something (pulling up for reverse on early models).FiatMac wrote:I missed that you had an early car.
Previous 76 Spider
Previous 76 Spider
