Replacement Dashboard
aslives
Post by aslives »
I'm looking to get a new dashboard for my 1978 2000 - something different from the normal tan wood - does anyone have any recommendations?
Re: Replacement Dashboard
are you asking about just the wood or a replacement dashboard? I have the wood in several different stains now
aslives
Post by aslives »
Hi Mark - I'm looking for just the wood - something a bit interesting. Can you post a link to what you have in stock?
michaelj
Your car is a: 1976 Spyder
Post by michaelj »
Check the parts section. There is a guy on there selling Phillipine Mahogany and it looks great. Reasonable too.
spidernut
Post by spidernut »
You can also veneer over the existing wood. This company even has a peel and stick version of the veneers.
http://www.veneersupplies.com/categorie ... __A__-__L/
John G.
1977 Spider (Sold 2017)
1979 Spider (Sold 2015)
1980 Spider (Sold in 2013)
1981 Spider (Sold in 1985)
I had a custom set of carbon fiber (not vinyl imitation) dash and center console made. I think they look pretty good.
Later I changed the center of the dash and installed 2 cup holders
MrJD
Your car is a: Looking to ask questions about a 79 2.0
Post by MrJD »
Dang mark... that walnut is hot...
spidernut
Post by spidernut »
Here's what happens when you put about 10 coats of high gloss urethane on a walnut dash.
John G.
bradartigue
Post by bradartigue »
spidernut wrote:Here's what happens when you put about 10 coats of high gloss urethane on a walnut dash.
That looks fantastic. What model year did the wood come from? I'm asking because some were solid wood and some had a veneer.
westy64
Post by westy64 »
pretty nice indeed.
looks like the back of the finest guitars... with a stronger sound, I guess.
spidernut
Post by spidernut »
It was purchased by the prior owner and never installed. It was solid walnut with a thin coat of lacquer. I sanded it down, then applied repeated coats (sanding in between) and then final sanding it with 2000 grit wet or dry paper then buffing it out.
John G.
MrJD
Post by MrJD »
That looks fantastic... I might copy you.
Mick124
Your car is a: 1967 Fiat 124 Spider
Post by Mick124 »
I have the following dashboard panels. New never installed.
