trunk arm & spring
- btoran
- Your car is a: 1975 Fiat 124 Sport Spider
trunk arm & spring
can someone pls post a picture of how the stock trunk arm and spring (the things that hold the trunk open) are supposed to be mounted? thanks.
1975 Fiat 124 Spider
Re: trunk arm & spring
Not sure if this helps. I posted several years back showing a solution of weak trunk springs. I put a smaller spring inside the big one that helped keep the trunk up.
Chris
Chris
- btoran
thanks but i was looking for a picture of the metal stick and spring assemple used to prop up the trunk when it's open.
- Curly
Curly from Oz
- btoran
that's it. thanks much!
edit: could you post a picture of what it looks like when the arm is retracted and laying flat against the inside of the trunk lid? thanks again.
