Exhaust Gasket Problem?
joelittel
Post by joelittel »
While snooping around my engine this morning I noticed this...
Does the black/brown gunk in the center of the circle indicate an exhaust gasket leak, or some other problem that is about to get worse?
wizard124
Re: Exhaust Gasket Problem?
Post by wizard124 »
From what I've read here, the #2 and 4 exhaust studs can leak oil. Can be as easy as using a sealant when screwing the stud back in.
divace73
Post by divace73 »
more than likely that is the gasket sealant, unless it is making a rather loud noise it is most probably okay, as wozard has mentioned you can get oil leaks from the threads
Cheers David
see my >>You tube channel<<
joelittel
Post by joelittel »
It doesn't make any odd noises at all, so I'll research the oil theory a bit.
