Seat tracks
Seat tracks
Does anyone know if there is "correct" way to install the seat tracks. It seems to me some seats move forward more than others. This makes removing the rear track bolts much harder. I know the seat adjuster is the inboard track and the handle points away from the center tunnel. I'm wondering if the other track has a front and back and the distance it travels is different.
Re: Seat tracks
If there reversed then I'm not sure how they can work, you have the handle to unlock them and they slide forward
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- perthling
Re: Seat tracks
These often bind up over time, with dust, dirt, carpet fluff and small animals getting in there. I found a good spray with CRC followed by some vigorous back and forth action (I'm referring to the seat base here - not whatever you were thinking
) was enough to free the seats up enough to get access to the screws to remove the seats. With the seats out I gave the tracks a good clean with more CRC then applied a bit of bearing grease to the slides and rollers before reinstallation.
I didn't take any pics of mine but I'm assuming from your question you think you may have swapped the idle track (the one without the handle) from one seat to the other? From memory the inner section of the slide has the longest travel towards the front of the car if that helps.
_______________________
Perthling
1974 Fiat 124 Spider (blade bumper 1756cc)
1974 Fiat 124 CC (same family since new)
1975 Fiat 124 CC (project)
1969 Fiat 124AC (project)
1997 Coupe Fiat 20VT (daily driver)
http://www.fiatlancia.org.au
Perthling
Re: Seat tracks
Yes I was inquiring about the track with out the adjustment handle. I have cleaned and lubed couple sets now and am not pleased with the force it takes to slide them and more so the distance the inner piece slides.
I guess a better way to ask my question is does anyone have the measurements of how far a track slides in each direction. If the center and outer pieces are set even how far out should the inner track move from that point. Also is that distance the same for both directions.
- perthling
Re: Seat tracks
After I cleaned up mine i found they slid with minimal effort - i could slide them with my fingers even before bolting them back onto the seat. I have had a couple of rails from cars I've pulled apart where the rollers have been out of round or the rail has become a little bent and that has bound them up very quickly.spider2081 wrote: I have cleaned and lubed couple sets now and am not pleased with the force it takes to slide them .
Perthling
Perthling
