V6 coming together...
- v6spider
Got the air cleaner...and made my own alternator bracket...thus weekend I am getting the rest of the materials I need for flipping my body on its side..
http://www.v6spider.com
- toplessexpat
Re: V6 coming together...
Looking good!
(Now you just need to ensure that the road in front is well illuminated to people can see as well as hearing you coming!)
- v6spider
Dude the only announcement I want to make is their car vibrating from the rumbling of me pulling up next to them!toplessexpat wrote:Looking good!
This thing is going to be a sleeper!
Rob
- v6spider
- v6spider
Cam is finally installed.. roller lifters, pushrods and roller rockers installed. Oil pump installed..timing cover and oil pan are left then finally intake...oh and paint. Should be done sometime this week...I'll post pics when it is fully done..
Cheers!
Rob
Cheers!
Rob
- v6spider
BORG Warner T5 5-speed manual out of a camaro.
I hate automatics..lol
Rob
Rob
- Your car is a: 79 spider
that's too pretty to use... i like it...
- 81SPIDERMATT
jealous ...just plain old jealousy
Take that carburetor off and FI that bad boy. Looks really cool man.
Any reason you chose a V6 as opposed to a modern 4 cylinder? Other than your name being v6spider? stupid question i suppose.
- v6spider
Hi Clark,
Well my v6 puts out over 300hp without turbochargeing supercharging or nitrous. And runs on pump gas. Plus parts are cheap as the 4.3l Chevy v6 is based on the design of the venerable small block 350 v8 so a lot of those parts cross over... many reasons why I am doing what I'm doing..
Rob
Rob
- v6spider
I painted the block flat black and the water pump and oil pan cast aluminum brake paint.
Rob
Rob
I like the idea man. Do you think you will have to strengthen the chassis at all? I have this image in my head of a 300HP fiat turning into a twizzler when you hit the gas pedal.
- v6spider
Clark: I have strengthened the chassis. Also, this is my second build and had very little strengthening in the first version and there was little twisting. Just rust issues that were unfixable necessitating the need to find a new body. It's so light that with all that power and even p225/50/r15 tires there is not much hookup..that is the fun of it!
Lanciahf: the heads and block are cast iron. Whole engine is only 75lbs heavier than the 2L twin cam plus I moved the battery to the trunk.
Rob
Rob
