124 Spider Dash
SeldomSeen
Your car is a: 2018 Fiat 124 Spider
124 Spider Dash
Post by SeldomSeen »
I'm probably going to install Csaba's full dash cap on my spider just because it's easy and inexpensive. Just out of morbid curiosity though, how difficult is it to replace the whole dash with the standard old style dash? Would a person need nerves of steel and the patience of Job?
It's never too late to have a happy childhood - Tom Robbins
1972 Alfa Romeo GTV 2000
1966 MGB Roadster
2007 MINI Cooper S
2018 Fiat 124 Spider Classica
SoFlaFiat
Re: 124 Spider Dash
Post by SoFlaFiat »
In my opinion, it's not too difficult. Should be four nuts on studs holding it in. Gauges are all on harness plugs. Glove box needs to be removed first, to reach attachment points behind it. Lots of stuff to undo but not too difficult. And a little patience goes a long ways...
That said, I put a dash cover on my 77, 20 years ago and it only started looking old a couple years ago. If installed well, you can barely tell the difference from the original dash. The only issue I ever had was the round vents not fitting too well. It is possible that AutoRicambi's version has fixed this problem. When I bought mine Csaba and Ramzi where not yet in business.
baltobernie
Re: 124 Spider Dash
Post by baltobernie »
SeldomSeen wrote:Would a person need nerves of steel and the patience of Job?
A little of both, yes, but more importantly, flexibility and the ability to work upside-down. A two-person job for the unitiated. Removal of the seats is helpful.
+1 on the cap longevity and looks. Tip: before installing the cap, use lots of IPA on the exiting dash to remove all traces of Armor All. Scuff the underside of the cap and the dash with 60 grit sandpaper around the perimeter. These two steps will insure a good glue joint.
SeldomSeen
Re: 124 Spider Dash
Thanks all. I will do the cap and make good glueing surfaces.
1966 MGB Roadster
2007 MINI Cooper S
fiat218
Re: 124 Spider Dash
Post by fiat218 »
It easy to replace the whole dash, nothing to it
I think overlaying with a cap would be harder,and not fit to good
Think about it,
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
