cruise control
81SPIDERMATT
cruise control
Post by 81SPIDERMATT »
81 spider ... done some searching and seem to be a lot about dual throttle cables on earlier models "poor mans cruise control" ...not wanting something like that.... googled aftermarket cruise controls and jargon reads like a medical book to me.... hoping someone can recommend a specific unit with good directions that would work on my car..... thanks for help and willingness to share.... Matt
SLOSpider
Re: cruise control
Post by SLOSpider »
Only installed one aftermarket back in the 80's that you glued magnets to the driveshaft and bolted up a sensor to the body to ready the rotations. Worked ok. If you need cruise control it just means your driving on the wrong roads :D
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
81SPIDERMATT
Re: cruise control
SLOSpider wrote:Only installed one aftermarket back in the 80's that you glued magnets to the driveshaft and bolted up a sensor to the body to ready the rotations. Worked ok. If you need cruise control it just means your driving on the wrong roads :D
agreed .. but on occasion got some highway miles to get to those roads
toplessexpat
Your car is a: 1976 Spider 1800
Re: cruise control
Post by toplessexpat »
I've got it on my '76. It's lethal... do not even think of using it as Cruise Control! The real thing means you touch the accelerator or the brake and it turns off... this doesn't!
As a handy throttle setting point for warming the engine though - it's excellent...
Andy
Many classic Fiats - it's a disease!
www.mirafiori.com
baltobernie
Re: cruise control
Post by baltobernie »
Spidermatt, I installed an Audiovox universal cruise control. SLO, yes it requires a magnet to be attached to the driveshaft. The unit works well, and makes long highway drives bearable. A gutted ashtray makes a good place for the controller, if you're trying to keep a stock look. (click to play)
supplyguy
Re: cruise control
Post by supplyguy »
There is nothing Balto Bernie cannot make. Don't ask about the ejector seat and rocket pods. The McGuyver of the DCFIAT club.
81SPIDERMATT
Re: cruise control
several different ones ranging in price from 90 to 300 is it.... Audiovox CCS100 Universal Cruise Control .... looks like the same switch in the ashtray
baltobernie
Re: cruise control
The orange wire goes to the .... no! the pink wire goes to ...
You going to Katie's tomorrow for Carl's run?
majicwrench
Re: cruise control
Post by majicwrench »
I've put in dozens of em over the years. Most of the modern ones do not use magnets, but use the coil(-) rpm signal. They are fairly simple to install, just follow directions.
Keith
supplyguy
Re: cruise control
Post by supplyguy »
Funny. Car is still in the paint shop. Carlisle will hopefully be its coming out party....was also the first event for me after I bought the car last spring.
On cruise control, agree the primitive lock-down-the-gas mechanism in my '71 has to be used judiciously. It was a blessing when I took the car on a long interstate drive with no traffic - would never use like a modern cruise control.
fiat218
Re: cruise control
Post by fiat218 »
In north Dakota', all we got is flat straight roads for miles, :( hell 200 miles of straight shots from one end of the state to the other
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
backyardbill
Re: cruise control
Post by backyardbill »
baltobernie, can you post a few photos showing how you installed the cruise control servo, etc., in the engine compartment?
TX82FIAT
Re: cruise control
Post by TX82FIAT »
I get the long flat road and making long highway drives more bearable as a reason cruse control is a desirable option. For me, I like the idea of one less modern convienance item on a classic roadster. One of the benefits of not having cruise control is the need for the driver to control and vary the RPM's. IMHO the engine performs better when you vary the RPMs on a long drive. No airbags, anti lock brakes, tire pressure sensors, micro chip key, reverse bumper sensors, self parking programming, cruse control, electric windows....
Driving the Spider brings me back to old time driving where the driver is in complete control. It's one of the things i love about these cars.
82 Fiat Spider 2000
03 BMW M3
07 Chevy Suburban
toplessexpat
Re: cruise control
Absolutely! Although - I do like my TPMS :)
www.mirafiori.com
Re: cruise control
I have a few photos. I installed the Audio Vox speed control actuator in place of the windshield washer bottle. If I were to do it again I would try and install it behind the headlight bucked behind the fender liner and have he wires and control cable pass through the fender well. I made a custom center console and mounter the controller in place of the ash tray.
Hope this helps. The AudioVox scs100 uses both magnets on the drive shaft and the coil pick up. I installed the magnets on the short drive shaft section between the transmission and the drive shaft bearing. Once I figured out the dip switch settings I am amazed at the cruise controls performance. I installed it about 6 years ago and it has over 20,000 trouble free miles on it.
