socket sizes
- Your car is a: 1974 124 sport
socket sizes
could someone please inform me the sizes of the crank pulley and pinion shaft nuts? in anticipation of some general maintenance. p.s.- my 1.5 inch socket seems to fit the crank pulley nut fairly well, so i'm assuming it's 38mm? thanx, ron.
if you can't be an example, be a warning.
Re: socket sizes
That is my understanding
Re: socket sizes
Re: socket sizes
ok, thanx for the input. i'm still hangin' on the size of the pinion shaft nut; or is it the same size as the crank pulley nut?
this is a '74 1800.
Re: socket sizes
1.5 inch works for the crank pulley nut and 15/16th inch works for the pinion shaft nut. whoda thunk it?
Re: socket sizes
rja, I'm off next week if you need help I would be glad to lend a hand.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
