Transmission sensor for what?
I am replacing my transmission and found all the wires broken off this . What is it and do I need it? I think I know what wires need to be soldered back on but they where not connected on the one I pulled out. Any help and all guesses will be appriciated.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
- kmead
Re: Transmission sensor for what?
Not really needed and likely the rest of what it was attached to no longer works either.
It is the 3-4 shift sensor and operated a feature that kept the rpm up to reduce oxides of nitrogen (NOx) emissions. There is an electrovalve in the engine compartment on the driver's side which opens and creates a throttle bypass loop.
There is also the reverse sensor which lights the backup light, if this is that one you should likely fix it or replace it.
Karl
Karl
Karl
1969 Fiat 850 Sports Coupe
1970 Fiat 124 Sports Coupe
1985 Bertone X1/9
1985 Bertone X1/9
Karl, I believe the one that activates the reverse lights is more towards the back of the transmission and scews in paralel to the trany.Thats kinda what I figured that thing was but just wanted to be sure. Transmission is in and all gears shift smooth. I did notice I had no back up lights but i will tackle that in the morning. It was 106 here today and I spent all day in the shop working on the car. I am spent. Thanks for the reply.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
