Snap Ring- axle shft
offshore
Post by offshore »
I have been trying for aboput 45 minutes to get the snap ring out so I can pull the axle. I can not get the snap ring to come out. I am able to get the snap ring pliers on the ring and squeeze the ring together, but I can not get the ring out. When I try and move the snap ring aaround to get it out the snap ring pliers come off.
Is there a trick to getting the snap ring out. I need help.
manoa matt
Re: Snap Ring- axle shft
Post by manoa matt »
Once you get the pliers in there and compress it some, take a small flat blade screw driver and get it between the housing and snap ring.
azruss
Post by azruss »
the ring needs to be compressed alot to clear the slot. If you dont have high quality snap ring plyers, they wont have the strength to hold under compression. I have the kind where you thread the compression rather than hold by hand. this makes it much easier to carefully manipulate the ring free of the groove.
