Hi,
I can barely get the ignition lead on the #4 plug correctly...
What's the secret-handshake-trick for removing, and even more-so, replacing, the #4 spark plug?
Mark
Number (#) 4 Spark Plug
- opus10583
- Your car is a: 1978 CS1
...Yes; I know what it means: Fabbrica Italiana Automobili Torino.
DOLCETTO: 1978 CS1; 10:1, DMS, 4-2-1...
ANDIAMMO: 2012 500 ABARTH
Acquista il Biglietto; Prendere la Gita! - Hunter S. Thompson
Re: Number (#) 4 Spark Plug
UNIVERSAL JOINT.
i agree , swivel joint. works great
Jim
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
2018 Alfa Romeo 4c Spider
East Grand Forks MN
1969 124 AS Spider
2017 Abrath
- TulsaSpider
Sounds like you need new motor mounts and/or transmission mount. It should be easy to access. Try jacking up the trans to level the motor and gave you more room
- Your car is a: 1969 fiat 124 spider
I used the swivel joint also, don't think the plug could be removed without one.
- manoa matt
With a universal joint and a 6-8 inch extension the plug should be no problem. The real bear however is getting the plug boot on and off. You can get what is known as spark plug boot pliers., there are several different designs
http://www.google.com/imgres?q=spark+pl ... =148&ty=96
http://www.google.com/imgres?q=spark+pl ... =107&ty=87
http://www.google.com/imgres?q=spark+pl ... =116&ty=47
http://www.google.com/imgres?q=spark+pl ... ,s:98,i:15
The pliers type can remove and install the wire boots, while the bent wire type usually only removes them. It may also help to remove the throttle linkage for more access.
