Today I noticed the brake fluid level in brake reservoir has gone done while the car has been parked for the winter. Upon further investigation it appears the leak is located on the line from the reservoir to master cylinder. It is not leaking from the hose joint but is leaking where the white plastic elbow goes into the master cylinder. I can move this elbow very easily from side to side.
Can anyone tell me how the elbow attaches into the master cylinder? Is it threaded? Does it only need to be tightened? Why would it start leaking? How can it loosen with the hose attached? Do I have to replace the master cylinder?
John
