Clock and Starting
Clock and Starting
My 1980 Spider has an analog clock installed in the dash. Problem I've had is that if I don't drive it regularly the clock wears the battery down. So I disconnected the clock and the car won't start, reconnect it, charge the battery and it starts. What is that clock connected to?
it is hard telling what a previous owner (PO) may have done.
how are you disconnecting the clock? are you shorting out a circuit when you do so?
if you disconnect the wires AT the clock and wrap the terminials with tape....are you saying the car won't start?
a red/black wire is hot, should connect to fuse # 8
a white/black wire should connect to the tach
at least, that is what my schematic says.
Clock
Doesn't the clock have a plug about 4" behind it?? If you unplug it nothing shoud be shorting.
I would consider buying a small battery charger they run about $35. I can't think of the name but they are designed to trickel charge batteries while the battery is in car, and the car is in storage.
For what its worth I start my car less than once a month in the winter and it cranks right over. Maybe your problem is more than the clock.
sounds like the wire between the ignition switch and the coil wire got tangled up with the clock.
is this possible? Wait a minute, with a long string of previous owners, anything is possible.
but, the clock should not be the cause of a drained battery. no way no how. i have a '78 and an '80 in storage. both have a OEM clock running in the dash, and both have a digital clock idling by in the aftermarket radio.
both of my batteries are connected to these vehicles which sit for weeks at a time without performing, being recharged, or even seeing my smiling face. both never fail to start the engine.
I just started the '78 last night from a battery that has not seen service, duty, or a charge since Christmas. All the time, the clock was (and is) running.
seems that i do not require those battery toppers unless i already have an ageing battery.
My car started up after 4 mos, no problem. I have the dash torn about on mine and have a real good look at the connector. Under normal conditions you should be able to disconnect this without a problem. BUT, since this is a FIAT, logic will not prevail! Since two of the terminals on the inside connector have double wires at single terminals, it is assumed there is contact, and the current would be shared in both wires. I guess that there is poor connection in one of these shared terminals. It doesnt have to make sence, and it is a educated guess. Go Bird!
Have you done any searches on this? I know there was at least 2 previous threads with identical problems. Here is mine: http://fiatspider.com:16080/forum/viewt ... highlight=
I had the same problem exactly, and it's documented in that post. It was an issue with the power to those circuits; all of which appear to be on the same one apparently. If those lights weren't on, it wouldn't start. So I had to flick the ign. off and on until they turned on, and it would start. Later, I found the problem which I replied about in that post. If you have any questions or need clarification, let me know
Chris
Chris
