Material used was a project type board from the local hardware store.
Cut tight around the battery box so the lip of the box is used as support.
Around Fuel Lines
I cut the back of the side board a little long (not really sure why). I may need the extra length when I install the carpet. If not I may cut it down a little.
1x2 Support for the left side board. I left about ¾ of an inch on each side of the 1x2 to create a lip. One side goes over the edge of the battery box and the other on the back lip of the trunk.
Template
Carpet install is coming soon.
Rick
