Turn signal ?
dulcimerbob
Turn signal ?
Post by dulcimerbob »
I went bumperless on my 76 and replaced the front TS with marker lights with two small bulbs in each one. The ts all work fine but my ts indicator light on the dash flashes once and quits when the signals are engaged. Not enough current , too much ? Need help. Thanks
SLOSpider
Re: Turn signal ?
Post by SLOSpider »
I suspect a bad ground. Run a jumper ground and start touching it to the bases front and rear and see if it comes back on. I had this problem with the left rear ground on the inside tail lamp hold down nut location.
1975 124 Spider
1989 Chevy k5 Blazer
1967 GT Mustang Fastback
Danno
Re: Turn signal ?
Post by Danno »
had a similar problem when I did mine. not enough draw. just for kicks try hooking up another light with bigger draw (or both lights to one side) to see it works.
dulcimerbob
Re: Turn signal ?
I suspect too little draw . The stock signals worked fine in conjunction with the indicator lights. Back to the drawing board. :D Thanks
Danno
Re: Turn signal ?
Post by Danno »
solution was to wire that front fender light into the same line. don't ask me how I did it, but I think i saw a "how-to" around here somewhere.....having those two lights on each side provided enough draw.
