124 Diff (rear axle) - Leaking Input Flange Fitting
ITA124
Your car is a: 1976 Fiat 124 Spider
Post by ITA124 »
G'day All,
Before I start. Aussie's call the rear axle a "Diff" as in differential.
Have removed the diff to look at a number of things, It's easier than working under the car. Anyway, the diff was leaking at the mating face where the drive shaft bolts to the diff. Suspecting a worn seal, discovered that the leak was not from the seal, but along the spline, around the washer that is held in place by the nut and out between this mating face.
What I want to know is how do I seal oil running along the spline to the mounting washer and nut.
The nut was tight and the washer looks quite smooth (cannot see leak path)
Here are a few photos.
Manufactured a removal tool. Copy of A.70345. Half hour side job that save much time.
The mounting side is 'oily'. Evident of a leak here. Plus the small puddle on the ground.
The oil seal side is dry, albeit dirty. No oil leaking past the seal
How do I seal the face between the washer and the drive flange?
Schematic for your reference
Paul
Fiat 124 Spider (Big Red Car. So my son tells me)
Toyota Corolla AE86 (Fiat as a daily driver? Not)
Fiat 128 Rally (Why did I sell this car?)
Fiat 124 AC (An iron ore waffle shaped like a 124. Donated to Sims)
Fiat 128 SL (First fiat)
manoa matt
Re: 124 Diff (rear axle) - Leaking Input Flange Fitting
Post by manoa matt »
You'll notice the oil seal rides on the back face of the driveshaft flanged fitting, the splined interface between the flanged fitting and the pinion are internal to the oil cavity. Oil will make its way past the splines through centrifugal force, past the washer/nut and into the area between the two bolted flanges eventually leaking out at the joint.
The sure way to prevent excessive oil weeping at that area is to install a new oil seal, clean all parts and splines with brake parts cleaner, apply RTV sealant to the splined interface, assemble, and install RTV sealant, or a paper gasket at the interface between the two flanges that are held together with four bolts.
