'81 2000 ignition switch wiring
ralphcap
Post by ralphcap »
While reinstalling ingnition switch all of the connectors came off their posts. I have a yellow, white, and a blue wire plus two red wires spliced together. What posts do the go on?
ralphcap
Re: '81 2000 ignition switch wiring
Post by ralphcap »
Looks like a PO rigged the ignition wiring in a weird way. However, I now have the problem solved (I think).
The wire colors you have are not the colors shown in the wire diagram I have for an 81 2000. Could it be the PO spliced in some wires of different colors??
Ignition switch terminal # Goes to color
30/1 Hot all the time fuse block terminal 9 black
30 Brown wire terminal block C17 brown
15/54 Fuse block terminal 1 and ignition pink
50 Starter and fuel injection red
INT Fuse block terminal 2, fuel injection and light switch blue with black stripe
Hope this is some help
ralphcap
Post by ralphcap »
Thanks spider 2081. I'll keep this for future reference. I traced wires back from the "PO motified" ignition switch short wiring harness. Everything seems to be working ok but I really would prefer to have the correct harness.
