After a lot of debating, wheel adapters, no wheel adapters, talking with local tire out-lets, most where against the wheel adapters and some where no help when I mentioned that I need the 4X98mm bolt pattern.
Let alone the whole hub centric issues. I went with the North American Distributor listed on the Rota site. I'm fairly new to the list but see/hear many good things about Mark (list member) from:
http://www.allisonsautomotive.com he also carries these rims and can get them to you. I stuck with the stock 4X98mm bolt pattern and the +15mm offset. As others had mentioned on the list. I usually don't splurge so much but the look of some after-market rims just sets the vehicle off. What's funny is UPS dropped this set on the front porch but is holding back for signature on the other set. They should be swinging back by today so I'll have four.
