She got an oil leak , a coolingleak and a fuel leak , dang is it that time of the month already.
Fuel leak is easy to spot its the diaphragm again , imo its not normal that after 1000km to go leak again so i'm starting to think one of the webers is damaged where the accelerator plate supposed to sandwish the carbs body.
The oil leak i tought resolved itself didn't seem like to have been resolved at all , due uphil parking in the garage the leaking dripped of backwards , i have a cardbord to proof that.
On top of that the cooling sytem supposed to be fixed earlyer isnt fixed no more , and i have fear there is a much bigger problem there also I really want you guys toughts here (this would also explaine the troubles before , leaks leaking caps etc )
The odd thing on the cooling system is that only after 30 seconds of driving the car out of the garage on the street the overflow bottle already flowed over. the cooling aid wasn't even warm. The hose seemed to be on extreme pressure Where does that pressure come from ? Only thing i can imagene is the pistons , whith other words i suspect a bad headgasket
The headgasket been replaced not 500 km ago that seems like a damn schort life, it better be the headgasket because a warperd , cracked head /block would be far worse On the other hand i have an oil leak in another gasket also somewhere in the front , and that leak wasnt there with the old gasket on this block.
On that last one , the oilleak there i suspect or the oilpan gasket , or the crankshaft returnring/gasket These repairs are going to be a PITA with no diaphragm , no (head)gaskets ,no pressuretester, no jack , no stands, no special tools, no money and not much skills ...
Far worst is the fact that i now have to go to the new job after next week ,ON BIKE , a stunning 3km .Even that one doesnt work properly , so need to fix that also this week. I have no high hopes for this summer with Belladonna i even considering getting my grüntlichen deutsche oldtimerbike a tune up and use that this summer Keeps me married also ,i CANT spend more on The little ittalian then on the wife
If any of you fine technicians need a vacation in Belgium this summer , your welcome to be our guest
