Need help...Starter I.D.??
fiatsaver
Post by fiatsaver »
I have been through a few Spider parts cars and have 2 extra starters.I have read in another post that the smoke coming from my starter(Hard to start) could indicate the windings were going bad,I did adjust timing and the engine did turn more freely.One of the starters is 9 1/2" and the other overall length is 11"-Which is the same size as the one on it.Will either starters work?The engine has been rebuilt has high comp pistons, carb, with literally no miles and has a 5 speed.Any ideas?
Thank you, Ray
Re: Need help...Starter I.D.??
all of the Spider starters will interchange. With a high comp engine you might consider one of the new gear reduction starters; they have a higher cranking rpm, weigh only half the weight of the original units
manoa matt
Post by manoa matt »
You may want to check the brushes, when they get oil soaked they will cause slow starting. Any good local alternator/starter rebuilder should be able to check it out, clean it, and if necessary install new brushes for under $30.
fiatsaver
Post by fiatsaver »
Thanks for the advice,where do I look for the gear reduction starter?
:D I have them in stock. You can check out pix at http://www.allisonsautomotive.com on the Products page
mdrburchette
Post by mdrburchette »
I'm going to be getting one of those cool things in the near future....if I still have money. :shock:
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
