32/36 Weber Carburetor Sputtering under throttle?
WadiaAbushanab
Post by WadiaAbushanab »
I recently put on a new intake manifold and 32/36 Weber carburetor. I had some issues where when I give it throttle it’ll sputter and then it’ll jump and go. I messed with the timing and got it a little bit better, but it’s especially noticeable when I’m going a little too slow for a higher gear, and then when I give it gas it sputters pretty bad.
Any ideas? I checked vacuum lines they all seem good.
bobplyler
Re: 32/36 Weber Carburetor Sputtering under throttle?
Post by bobplyler »
If it only happens when you get on the gas, it sounds like the accelerator pump.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
WadiaAbushanab
bobplyler wrote:If it only happens when you get on the gas, it sounds like the accelerator pump.
It’s a brand new carb off of vickauto I don’t see why it would be an accelerator pump
bobplyler
Post by bobplyler »
I would call Vicks. They would know more. They've been very helpful when I had to buy suspension parts.
Anbele
Your car is a: 1979 Spider 2000 CS2
Post by Anbele »
I encountered the same issues when I installed a new manifold…I resolved them by making sure I had the correct height of the Carburator as before—when exchanging the manifolds, the new one will require a spacing adapter of at least an 1” in thickness. Which will make the accelerator rod linkage work as intended. Of course, making sure that the Carburator was properly set and making sure there were no vacuum leaks whatsoever. Especially in the new spacing adapter. And adjusting the timing by loosening the distributor and moving it accordingly to get a smooth running engine. (Of course, at some point—sooner rather than later—the timing has to be adjusted properly with a stroboscopic light gun.)
An important point: Is it an authentic Weber, or an aftermarket copy? Occasionally, some knockoff carbs suffered with issues of blocked passageways, goofy accelerator check valves, etc. Very easy to check. With the engine off, remove the air cleaner so you can peer into the primary barrel with a flashlight. Work the throttle linkage by hand and you should see a steady stream of fuel squirting into the middle of the barrel (on some carbs it's both barrels).
70spider
Your car is a: 1970 Fiat spider
Post by 70spider »
I am currently dealing with the same issue. I have hypothesized that my car is running way to rich, I live at 6000 ft., and my Carter fuel pump's pressure is to high for the carb. My solutions will be to put an inline fuel pressure regulator and gauge in it and re-jet the carb.
Your carb may be running to rich, even at sea level I had to lean my carb out a little.
The stock 32/36 carb jet sizes are:
Jet Primary Secondary
Idle 60 50
Main 137 140
Air Corrector 165 160
When I lived at sea level I went down 2 sizes on the idle (p50 s47.5) and down one size on the mains (p135 s137) and up one size on the air correctors (p170 s165) and that helped a lot.
2002 Mazda Protege5
2013 Buddy 170i
MMRMVA
Your car is a: 1978 Spider
Post by MMRMVA »
This is not exactly on topic, but this is a new thread about the Weber. When I removed ours, there were two paper gaskets sandwiching a base plate/spacer that also had some paper on both sides. Can I reused these, or should I be getting new? All 3 items? Where do I get these?
Anbele
Post by Anbele »
Three vendors that might help you:
—Vick’s auto
—Midwest Bayless
—Autoricambi
Oh, one more:
—Mr. Fiat
Good luck!
