3D Printed Stuff (seat belt guides, phenolic spacer, buttons, bracketsetc)
GTRaptor
Your car is a: 1979 Fiat Spider 2000 CS2
Post by GTRaptor »
Wanted to start a new thread for everyone that has 3D skills to post their designs.
a) First in my list is the seat belt guide (back of the seats).
This is NOT a PERFECT copy of the original but CLOSE.
Al measurements are to the millimeter, 3mm bolts required.
b) Phenolic spacer for weber 17mm
c)Center caps for aftermarket wheels
d) Soon: Center Console vents
LINK TO FILES: https://www.thingiverse.com/thing:4977654
NOTE: SUBMIT YOUR IDEAS !!!!
1979 Fiat Spider
GTRaptor
Re: 3D Printed Stuff (seat belt guides, phenolic spacer, buttons, bracketsetc)
Post by GTRaptor »
1979 Fiat Spider
TheBender
Patron 2019
Patron 2019
Your car is a: 1978 124 Spider
Post by TheBender »
GTRaptor wrote:NOTE: SUBMIT YOUR IDEAS !!!!
A 3D printed clock gear would be amazing. The plastic orange clock gear that breaks on everyone’s clocks! And nobody seems to have the replacement.
Nut124
Post by Nut124 »
GTRaptor, that is pretty amazing!
Head rest sleeves?
I agree, pretty cool! I don't have any 3D skills, but the one part I'm always on the lookout for is the plastic cam inside the early Sipea ignition switches. This part is mounted on the shaft and opens and closes electrical contacts in the switch depending on where the key is. Over time, the lobe on the cam wears down (melts actually) due to the heat generated from contacts that are failing, and the the contacts stop working entirely. Usually the "ON" position contacts, and sometimes the "START" position ones.
GTRaptor
Post by GTRaptor »
CLOCK...Yes can do that, my clock is running but a gear broke, i have to disassemble it to get the gear and dimensions, but if SOMEONE has the gear already out, take measurements:
1. pivot diameter (axle)
2. Inner diameter (before teeth start)
3. Outer Diameter
4. Number of teeth
5. Width
1979 Fiat Spider
GTRaptor
Post by GTRaptor »
18Fiatsandcounting wrote:I agree, pretty cool! I don't have any 3D skills, but the one part I'm always on the lookout for is the plastic cam inside the early Sipea ignition switches. This part is mounted on the shaft and opens and closes electrical contacts in the switch depending on where the key is. Over time, the lobe on the cam wears down (melts actually) due to the heat generated from contacts that are failing, and the the contacts stop working entirely. Usually the "ON" position contacts, and sometimes the "START" position ones.
Everything is possible, but need the measurements.
1979 Fiat Spider
Thanks, Raptor! I don't have one of these handy right now (both of mine are installed in ignition switches in cars), but if I happen to have one out in the next few weeks, I'll check back with you.
PS: Good work on finding that Veglia clock fix on the xweb.
GTRaptor
Post by GTRaptor »
New part...
Parking brake "cover" for the console.
https://www.thingiverse.com/thing:5118206
1979 Fiat Spider
lanciahf
Your car is a: 1984 Pinninfarina
Post by lanciahf »
Very cool! Thanks for sharing
rodo
Your car is a: 1981 Spider
Post by rodo »
FINALLY! So glad someone has taken this on. That cap above the ebrake for the console is brilliant. But I could not download the plan.
What about modeling those damn rear seat belt guides? Those are $50 each! Printed ones should work perfectly.
I'm sure I am not the only person on the forum to cheer on your efforts.
profcucchi
Your car is a: 1979 Fiat 2000
Post by profcucchi »
These look great.
I've attempted center caps, but it's the springy part that holds them in that's a hassle.
1979 Fiat 2000 "Luigi"
GTRaptor
Post by GTRaptor »
Use PETG for the caps, it is not as stiff as PLA, it has some flex and it is tougher
1979 Fiat Spider
dkmerth
Post by dkmerth »
Love this idea. Finally someone duplicating Fiat stuff! Finally my 3D printer can make more than useless trinkets!
Thanks!
anggrazi
Your car is a: 1980 2000 spider
Re: 3D Printed Stuff (Parking brake "cover" for the console. )
Post by anggrazi »
Id like to buy Parking brake "cover" for the console.
