Charging system mystery.
JULIAN911
Re: Charging system mystery.
Post by JULIAN911 »
Found this thread after several days of scratching my head why my brand new 95A alternator not charging... The PO removed the charge indicator bulb!!!
Put the bulb back in, alternator now charging nicely at around 14.3V, except when I turned the key completely to the left to remove it, the Battery charging bulb comes on... WTH? If I just turn the key slightly to the right (and nothing else energized), the bulb would go off but then I can't remove the key from the ignition.
Any help where to begin would be greatly appreciated!
Is there a chance some one installed a Lada ignition switch in the car in place of the original Sepia? If so the Lada ignition switch has a pair of contacts that are mating when the key is removed.
Sipea switches have Sipea engraved in the shinny metal face of the ignition switch. Lada ignition switches have Roman numeral type symbols stamped in the shiny face at each key position.
JULIAN911
Post by JULIAN911 »
"Lada ignition switches have Roman numeral type symbols stamped in the shiny face at each key position."
yes, mine looks as described above. So what should I do now?
SteinOnkel
Post by SteinOnkel »
Wire the lada switch correctly.
JULIAN911
Post by JULIAN911 »
Great advice!
Googled the wiring diagram and rewired it - now it works as it should! The PO had the blue wire on the INT terminal instead of on the #15 terminal with the pink wire.
Thank you for pointing out that I may have the Lada switch, that was the ticket for troubleshooting in the right direction.
SteinOnkel
Yep, no problem. Glad it worked out :)
I would add a relay when using the Lada switch though. They are cheap and the contacts are not exactly amazing.
DieselSpider
Post by DieselSpider »
SteinOnkel wrote:Yep, no problem. Glad it worked out :)
Add the relays regardless of which ignition switch is in the car since the lack of relays for the starter, headlights, etc is the most common cause of the OEM switch failing.
+1
dinghyguy
Your car is a: 1981 spider
Post by dinghyguy »
+100! add relays
1981 Red Spider "Redbob"
1972 blue Volvo 1800ES "Bob"
1998 Red Ford Ranger
