Rear Sway Bar Question
I am thinking of adding a rear sway bar.
For those of you who have added a rear sway bar, obviously they keep the car flatter, but I am curious if they cause the ride to deteriorate noticeably, i.e. harsher in the rear? More pounding, worse on potholes, etc? Any noticeable difference, or is it all good?
Pete
AndyVAS
Your car is a: 1980 Fiat 124 Spider
Re: Rear Sway Bar Question
Post by AndyVAS »
I've not felt any difference in ride quality.
Andy Phillips
Vick Auto - Technician, Performance Engine Builder & PFI Developer (with ITBs)
http://www.vickauto.com
Stock parts or Performance parts we've got what you need.
Thanks, that is good to hear! This is on my upgrade list fer sher.
Pete
chrisg
Your car is a: 1971 FIAT
Post by chrisg »
I'd put the rear bar in with lowering the CG of the car as a bit of a must. My '71 does not have a rear bar & once I re-acquaint myself with it's slinky handling, it handles well...clearly, these cars were designed to handle with body roll. Otherwise, I always use rear anti-sway bars in my 124s. I have never noticed that this particular change causes the ride to be harsh, but on the other hand a cushy ride in a 124 sounds like my own concept of a room in hell! There is probably much debate to be made on a larger front bar & you have to remember ride height, springs/shocks & tire width (and aspect) all factor in, but for a rather normal Fiat 124 street machine, I think the rear bar is a must.
Chris Granju
Knoxville, TN
I am running Sumitomo 195/60-14 all around, and the track has been widened both front and rear by ~2.5" (30mm at every wheel, with Serpent Motor Sports' spacers/converted to studs). It sticks really well to the ground with this setup and the stock front bar, so I am not likely to put a larger front sway bar on, but I am interested in reducing the rear inside wheel lift and what that may do for the ride overall.
Obviously it should improve the overall flatness and handling, but the ride is pretty harsh already, even with the front tires down below 30psi. If there were a significant decrease in ride quality, I would probably not do the rear bar. I don't race this car, or even drive it overly hard, but if a rear bar would keep it a little flatter without a lot of consequence, I would be likely to do it.
toplessexpat
Post by toplessexpat »
I found doubling up the rear long arms inboard a nice approach that didn't change the ride in a straight line, but tightened up nicely around corners.
One spider runs a thick rear seat, and it's considerably tighter all round.
www.mirafiori.com
Do you mean welding in new mounts and adding a second set of trailing arms in back? I am not sure I understand what you are saying.
toplessexpat
No - put an extra set of arms inside of the existing ones using the same brackets. Add a fender washer to retain the bushing on the very inside (not sure it's essential, but I did anyway), and use longer bolts (ACE sells them)
www.mirafiori.com
Odoyle
Post by Odoyle »
I installed an Adco rear sway bar on my 83, of which I think offers some pros and cons. The pros being noticeably better turn in control at all speeds. The behavior of the back end feels more predictable and stable. Cons are the holes you have to drill into the rear frame rails for the u-bolts. Also, the back end seemed to be bucking a little when I let off the gas, and the bar was hitting the lower part of the diff sometimes. Solved the issue by having some spacers made so the bar wouldn't contact the differential. In retrospect, this issue may have been attributed to the US spec rear springs, which throw off the geometry of the car. Also, be careful that you don't put your rear metal brake lines at risk of being crimped when routing the U-bolts over the differential. I saw a post where someone else had done it like that and did the same only to find that the brake line got crimped and had to replace the rear hard lines. And sometimes the the u-shape locating bracket (above metal spacers) shifts away from the u-clamp requiring it to be readjusted. Contacted Adco at one point with some questions/feedback and essential dismissed my assesments. Over all, it a decent addition, considering it's installed correctly.
johndemar
Your car is a: 1976 Fiat 124 Spider
Post by johndemar »
My experience is that the ride itself, and far as harshness is concerned hasn't changed at all.
What is apparent is the improved cornering ability, with the rear tires staying flatter with the pavement.
76 Fiat 124 Spider
One owner since July 20, 1976
Amadio Motor, Jeannette, PA
azruss
Post by azruss »
I installed an Addco rear bar 4 years ago. Left the front sway bar stock. Running stock 71 springs in an 80FI. 195/55x15s. I run 29 psi in front 28 psi in back. The ride is harsh due to the tires, not the sway bar. It did take the push out of the car in the corners. (my main objective). It also makes the inside rear tire lift in a hard corner. I solved that by installing a LSD
Thanks all for those inputs, that is very helpful. :)
