Suspension parts preplacement
barnesjtsl
Your car is a: 1979 Spider
Post by barnesjtsl »
79 Spider 2000
I have ordered new a-arms (upper and lower), Tie Rod Kit, and Center link.
My purpose for ordering these is that I'm a little nervous about the ball joints.
While I'm replacing all this anyway, is there anything else under there that anyone would suggest I replace being I have it all apart anyway.
jb
bobplyler
Re: Suspension parts preplacement
Post by bobplyler »
Maybe shocks and brakes.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
lglade
Post by lglade »
My steering idler needed new bushings as it was allowing the passenger side front wheel to wobble about 1/4 inch on its vertical axis. If you're going to be down there working anyway, give your idler some careful attention to make sure that yours has no unwanted play in it. You might take the opportunity to drain and fill your steering gear while you're at it too.
Lloyd Glade- Mukilteo, WA
1962 Fiat 500D - wife's car
2015 Subaru Outback
2017 Ford Focus RS
njspider
Your car is a: 1982 spider
Post by njspider »
hey barnesjtsl, I'm thinking about the same project this spring. Please let me know how easy/hard it is to do and what to avoid, thanks
klweimer
Post by klweimer »
Sway bar bushings, rubber brake lines to calipers.
profcucchi
Your car is a: 1979 Fiat 2000
Post by profcucchi »
I went to a Fiat mechanic and had him take a good look. Bushings were swollen, ball joints were iffy, control arms were ugly, shocks were leaking oil. Surprisingly, the rear suspension was upgraded by the PO.
Then I called a vendor and he talked me through what was needed - basically a new front suspension. Not cheap.
A mechanic shop would take about 8 hours. My understanding is it's the springs that add time.
1979 Fiat 2000 "Luigi"
