Veneering Wood Dash Parts
davery
Your car is a: 1985 Spider
Post by davery »
Anyone veneered the wood and wood-like parts of the dash? If so, what type of veneer and glue? Any problems? Pics?
Don Avery
Dayton, OH/Sarasota,FL
1985 Pininfarina
2011 Eos
2012 Mercedes E550 Cabriolet
124JOE
Re: Veneering Wood Dash Parts
Post by 124JOE »
use contact cement
joelittel
Post by joelittel »
Someone said the used this site http://www.veneersupplies.com/ for all their veneering needs.
davery
Post by davery »
124JOE wrote:use contact cement
I was under the impression contact cement is not to be used on raw veneer.
Don Avery
1985 Pininfarina
2011 Eos
there are many posts on this:
Here is one: http://www.fiatspider.com/f15/viewtopic ... ard+veneer
davery
Post by davery »
I should have been more specific in that I was looking for someone that has used veneer on an 83-85. I am concerned about gendering the metal center sections. Specifically, the top center seems to bend easily.
Don Avery
1985 Pininfarina
2011 Eos
DieselSpider
Post by DieselSpider »
davery wrote:I should have been more specific in that I was looking for someone that has used veneer on an 83-85. I am concerned about gendering the metal center sections. Specifically, the top center seems to bend easily.
I wood veneered/Formica laminated metal doors for a living and we used flame retardant HyBond or regular old fashioned flammable HyBond contact cement. It has to be warm and dry to prevent condensation and you need to be cautious about sweating on the material as any water/moisture or water based cements/glues on metal can blacken or rose tinge the veneer as the metal rusts and corrodes from behind. We used a good automotive primer on the metal allowing it to dry overnight before applying the contact cement and a paper backed door veneer which is about 1/8 of an inch thick when veneering metal. Wipe down the metal with pure alcohol before applying the primer to ensure good adhesion.
davery
Post by davery »
davery wrote:I should have been more specific in that I was looking for someone that has used veneer on an 83-85. I am concerned about veneering the metal center sections. Specifically, the top center seems to bend easily.
Don Avery
1985 Pininfarina
2011 Eos
davery
Post by davery »
I am thinking of rearranging the center dash, so I may just make a new metal face. Good idea about painting prior to veneering. I have been doing research of using white wood glue and letting it dry, then ironing the veneer on the dried glue to attach. I am concerned about using a glue that bleeds through a raw veneer and this seems to be the best option.
Don Avery
1985 Pininfarina
2011 Eos
DieselSpider
Yes you do have to be careful with some of the paper thin veneers especially those that have a lot of tannic acid in them as they can discolor when a water or milk based glue is used or a contact cement containing a red or really any heavy dye is used.
