I am going to remove my luggage rack temporarily in order to use my new dual action polisher on the trunk. I looked around the forum but didn't see the answer to this question...is there anything I need to replace (grommets, seals, etc.) when I reinstall the rack?
If anyone has experience with this and has some tips, I'd really appreciate them.
Luggage Rack Install
- Your car is a: 1977 Fiat 1800
- 124JOE
Re: Luggage Rack Install
removal of the rack is not hard
there is 4 bolts in the trunk to pull out
you may need to search a bit for gaskets if you want new ones
or look onto making some new ones.say from an old innertube
I used flat rubber washers i found at a hardware store. In the plumbing dept.
Thanks for the suggestions!
