Brake Hose Removal
ralphcap
Brake Hose Removal
Post by ralphcap »
1981 FI 2000 spider front brakes. To remove the brake hose from the brake line turn the 10mm nut on the brake line clockwise or counterclockwise?
azruss
Re: Brake Hose Removal
Post by azruss »
they are all standard thread. ccw to loosen
bluespider262
Your car is a: 1979 Spider
Post by bluespider262 »
Just out of curiosity, are there any CW to loosen nuts/bolts on a spider? IIRC some cars have crank or hub nuts like that, don't they?
njoconnor
Post by njoconnor »
Right hub nut is CW to loosen. About all I ran into during my suspension work. Unlike a 80's MOPAR, even all the lugs are ccw to loosen... :)
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
bobplyler
Post by bobplyler »
Removing the hose at the hard line can be very difficult. I've found the best tools for that is Vise Grip 4LW locking pliers
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
Jimb
Your car is a: 1985.5 Volumex
Post by Jimb »
bluespider262 wrote:Just out of curiosity, are there any CW to loosen nuts/bolts on a spider? IIRC some cars have crank or hub nuts like that, don't they?
Crank pulley nut
ralphcap
Post by ralphcap »
Thanks for the tips. I was able to disconnect the driver's side brake line without a problem but broke the brake line on the passender's side. Looks like I will have to replace the complete brake line. I have enough line for a repair but it appears that a repair is not possible for a shade tree mechanic like me. Any suggestions for avoiding a brake line replacement?
