My late mid-life crisis 77 Spider
azruss
Re: My late mid-life crisis 77 Spider
Post by azruss »
An inch out and you should be clear of the pilot bearing. Now, the only thing between you and removal is the clutch. It will want to bind with the slightest bit of misalignment. If you are planning on replacing the clutch, you may want to shower the area through the 1" gap with WD-40 or the like to get some lubrication on the splines. You will have some clean-up to do afterward. check your gap top to bottom and side to side. try prying with 2 pry bars on each side at the same time. If you have any long bolts that fit the 2 side holes. put them through the bell housing holes, put a nut on the bolt in the 1" gap and screw the long bolt into the threaded hole on the engine. now you can use the nut to exert pressure on each side of the bell housing. you may want to whack on the engine at the back while you have the pressure on the bellhousing to get the splines to loosen up or shake the back of the tranny.
Nanonevol
Post by Nanonevol »
Ok! I hate to ask for help but I was starting to think I was blacklisted or something for the lack of response (rroller excepted). Lots of insights for me, a novice as to clutch, flywheels, etc. I expect yes to put in a new clutch and anything else so I don't have to do this again in some time! I like the bolt idea - very clever. I was about to get out the wood splitting wedges. It's still therapy for me and keeps me off the streets, and I'm a persistent SOB - it'll come out...eventually. Thank you.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
After all this work, make sure you put in a lightened flywheel, it makes an amazing performance difference!
Nanonevol
Post by Nanonevol »
Well, Successo!
Finally realized my original problem was I hadn't taken off that tinny cover at the front of the transmission. (Duh!) After that I got it slid back much further but after hours of struggling, noticed I was hung up on my exhaust downpipe. thanks rroller and azruss and I just have one more thing to say..... Sonofabitchhhhhhhh!
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
Nanonevol
Post by Nanonevol »
In all the threads and instructions I've read I never heard mention of removing that thin tinny flywheel cover at the front of the transmission as required for transmission removal. As a novice and not knowing which piece the flywheel was going to stay with on the removal, I didn't notice it as a problem - maybe it should have been obvious. Correction - looking back, now i see removal of flywheel cover in threads. Oh well, pobodys nerfect. On to the transmission rebuild!
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
Nanonevol
Post by Nanonevol »
When you're taking out your transmission, don't be a dummy and forget to remove this first like I did!
Now I'm deep into it:
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
Good luck with it, keep us informed and lots of pics too!
Online
Post by AriK »
+1 on that. You're very brave and not the dummy you lead us on to be.
Nanonevol
Post by Nanonevol »
Thanks for the comments! I'm taking lots of photos of the disassembly for reference.ImageImageIt will be very gratifying if I can rebuild this and get it back in the carImageImageThis is where I'm currently stuck. Need to find a "machine shop" to help me get off the bushing here holding on first and second gear. Frustrating because I'd like to look at second gear as that's the one that I couldn't shift into.Otherwise going smoothly with some things that are supposed to be difficult being easy and visa versa.Besides the photos I'm putting parts in labelled baggies and trying to be very organized.ImageThe parts look to be in pretty good shape overall. Can anyone recommend what parts I might replace routinely on a 40 year old gearbox with close to 100K miles on it?
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
Nanonevol
Post by Nanonevol »
Took the main shaft to a friendly mechanic who pushed the gear and bushing off for me. Find out how on Monday. Meanwhile, looks like I need a clutch anyway:Image
I know lots of you do this stuff everyday but it's virgin territory for me and kind of exciting.
Picked these up cheap on E-Bay. What do you think?Image
Maybe under the hood...
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
leave em on the hood and start a long distance trucking company with the car.
Nanonevol
Post by Nanonevol »
I think they look kinda cool there. 8)
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
azruss
Post by azruss »
If you mount the air horns there, you will have to mount bull horns on the front of the hood. :roll:
Plus mud flaps with that wonderful female outline.
Nanonevol
Post by Nanonevol »
Well the bushings off with the help of a local garage so now I can see what might be causing it not to shift into second gear.
Time to order parts.
1977 Fiat Spider
1985 Jaguar XJ6
1966 BSA Lightning
