Fuel Injection Hose
PureStyle
Your car is a: Fiat 124 spider 1977
Fuel Injection Hose
Post by PureStyle »
Hi, first time poster so sorry if I have put this in the wrong section. I've just purchased my 1981 2000i spider from a nice chap in Wales, He was kind enough to deliver to me me in the South East, only problem is that on arrival the car decided to spill its petrol all over the drive hence one split fuel injection hose!! I'm going to replace this but I have two questions.
1. What mm pipe do I need? I keep seeing different answers 7mm or 8mm?
2. Any good tips on getting the pipe lubricated enough to slide on?
Hope to be a regular on here as I love the cars and am hoping to get mine to a very good example.
Cheers
Jon124
Re: Fuel Injection Hose
Post by Jon124 »
Hi there,
I just replaced the gas tank in my 81 and all the hoses. I used 5/16 (8mm) for everything and it worked great.
1974 Honda CB350F
1981 Fiat Spider 2000
vandor
Post by vandor »
You can use 7.5mm or 8mm. Most people fit clamps to the hoses, as it is quite difficult to press new hoses in the original 'hat' type washers.
I would replace all the high pressure hoses both in the engine compartment and by the fuel pump/filter.
PureStyle
Post by PureStyle »
Thank you both for your prompt responses, looks like I've certainly joined the right forum :-D
I found applying a little light grease to the end barb and heating the new hose with a hot air gun make pushing the new hose fully into the original cup mush easier. I think it might be an over kill but I install a stainless steel pinch clamp on all the new connections. The photo below shows the pinch clamp.
