Panhard rod bent?
rjkoop
Panhard rod bent?
Post by rjkoop »
I had a bit of a tight fit for the muffler/exhaust between the car and the panhard rod on my '81 Fiat Spider. Here's what the panhard rod looks like.
Front underneath looking up.
Looks bent too far to me. If so, can I remove the bolts holding it on, remove it, and straighten it? Is there pressure on the bolts and maybe I should jack up the car 1st? And I think the panhard rod is supposed to be a little bit bent on my '81. Also how do I determine how much it should be bent?
vandor
Re: Panhard rod bent?
Post by vandor »
OMG, yes, it is bent. Looks like they used it to pull or tie down the car with it.
4uall
Post by 4uall »
certainly looks bent to me :shock:
here is a few pics of mine fyi
no issues removing, no pressure on the bar
rjkoop
Post by rjkoop »
Thanks guys. I'll remove, try to straighten back to original, and reinstall. Hope I don't have anymore project creep... I hate project creep!
AndyS
Your car is a: 1967 Fiat 124 Spider
Post by AndyS »
once it is bent like that and you straighten it back, it will be weaker, as the metal tube gets damaged from being crimped . this happened on my car, and we had to sleeve it (welded a larger split tube in that area) where it was bent to make it stronger. nice side effect--it tightened up the rear and the car handled better afterwards.
rjkoop
Post by rjkoop »
AndyS wrote:once it is bent like that and you straighten it back, it will be weaker, as the metal tube gets damaged from being crimped . this happened on my car, and we had to sleeve it (welded a larger split tube in that area) where it was bent to make it stronger. nice side effect--it tightened up the rear and the car handled better afterwards.
Great info. Thanks. I'll keep that in mind when I remove.
DieselSpider
Post by DieselSpider »
Its creased so your better off replacing it if your not equipped to weld in reinforcements.
azruss
Post by azruss »
+1 with Diesel on this. once that pipe has been crimped, it has lost its strength. if you sleeve it, you have added a bunch of weight. should be easy to find a used one.
njoconnor
Post by njoconnor »
While shopping for a used one, keep in mind that a new one from A/R is about $66, and comes with new bushings already installed.
Just sayin'..... :)
Neil
Neil O'Connor
Madison, WI
72 FIAT 124 Spider
ex-71 FIAT 124 Coupe
rjkoop
Post by rjkoop »
Yep. Ordering a new one for AR is the way to go for sure. If I do my best to straighten for now can I use it until I get the one from AR? I'm heading down to my sisters in NYC (where I'd get it shipped to) July 4th weekend so I couldn't get it until then.
bobplyler
Post by bobplyler »
I'd just leave it alone. Trying to unbend it will cause a loss of strength. A new one is the way to go.
1979 Fiat Spider (since new)
1999 Honda Shadow VLX 600
AndyS
Post by AndyS »
when they are bent like that, they can also throw off the rear alignment angles. the thing keeps stuff at the right angles back there.
InfinityAero
Post by InfinityAero »
AndyS wrote:when they are bent like that, they can also throw off the rear alignment angles. the thing keeps stuff at the right angles back there.
Wow, what's the toe set to on this sucker? I've got an 1/8" of toe on on the left side of mine, I can only imagine how off the rear alignment is with that panhard rod...
rjkoop
Post by rjkoop »
After straightening and reinstalling a few moths ago car tracks straight and no uneven wear on tires. Had the alignment done and they didn't notice anything out of whack. That being said I'm probably redoing the rear suspension over the winter. And at that point I'll replace the panhard rod.
InfinityAero
rjkoop wrote:After straightening and reinstalling a few moths ago car tracks straight and no uneven wear on tires. Had the alignment done and they didn't notice anything out of whack. That being said I'm probably redoing the rear suspension over the winter. And at that point I'll replace the panhard rod.
Crazy, you'd think with a rod that warped the thrust line would be way off, guess the components all wore together in a good way...
