Turn signal and brake light issue
tonyfromjersey
Post by tonyfromjersey »
Here's a new one I just found when working through the car. The left signal works fine, but when I turn right, the taillight and turn signal light take turns flashing. Is this a wiring problem, or what could cause this?
Tony
77 Fiat Spider
05 BMW 325xi
1963 Boeing KC-135R
racydave
Re: Turn signal and brake light issue
Post by racydave »
First, ( and this applies to all car systems on your Fiat ) check and clean the grounds!
it's definitely a bad ground on the right light
tonyfromjersey
Thanks. I guess I just pull off the back panel, inside the trunk, and follow the wiring, or is there an easier way?
Tony
77 Fiat Spider
05 BMW 325xi
1963 Boeing KC-135R
mdrburchette
Post by mdrburchette »
There should be a ground at the taillamp and may also be a ground at the rear side marker lamp. Electrical gremlins live in Fiats. I can't stress enough how important it is to kill these critters when you catch a glimpse of them!
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
