springs and bushings, old vs new
SpiderJunkie
Your car is a: 1978 Spider -California Car
Post by SpiderJunkie »
Original Front Spring
New Front Spring VS old
Wire Diameter Old Front
Existing Rear Spring Height
Upper Control Arm New Bushing Partially Installed
When installing the new rubber bushings do you push them in till they stop, or push them in some and when the bolts are torqued that draws them in?
SpiderJunkie
Fenelon Falls, ON
Canada
81SPIDERMATT
Re: springs and bushings, old vs new
Post by 81SPIDERMATT »
push them till they stop
wizard124
Post by wizard124 »
I remember working the bushings in a little at a time. My concern was if the bushungs were fully seated, they may not span the tower.
engineerted
Post by engineerted »
I would measure the distance between the old ones then press the new ones to match.
Ted
redcars
Post by redcars »
It has been three years since I did my bushing, but I know that either the top or bottom bushing do not go in all the way. I do not remember which it is. If you push the ones in all the way that are not suppose to be you can take them out and put them in the trash can. If you only have one side apart look at the other to see which it is . Other wise ask for a picture or someone on here will know and tell you.
1987 Lotus Super 7 clone
1981 Fiat Spider 2000 AT
1982 Fiat Spider 2000 5sd
1970 Fiat Coupe
toyfiats
Post by toyfiats »
As noted by others, do NOT press the upper bushings (as shown in your picture) all the way in. If you do you'll have to start over with new bushings.
Look at how the existing bushings are seated, follow the method in the following link, and press them in gradually and test fit them as you do, and you should be fine.
http://www.mirafiori.com/~thad/bushing.html
The bottom bushings, on the other hand, need to be pressed in all the way.
SpiderJunkie
thanks for the replies.
I used the above method on the upper bushings, except I used a vice to compress the assembly, there's more control with a vice on the amount of insertion and keeping them square to the arm. My top ones went in all the way to the stops and the arm slides nicely over the structure. In my theory unless someone has over torqued the assembly and bent the arm the top bushings should go in to the stops, or why would they put stops on them? The bottom bushings have no stops.
SpiderJunkie
Fenelon Falls, ON
Canada
toyfiats
Post by toyfiats »
SpiderJunkie wrote:thanks for the replies.
Glad it worked out for you. Pushing them in "to the stops" versus pushing them in "until they stop" is two different things, as you _can_ drive the upper bushings all the way in, which you obviously don't want to do. Many years ago when I was much younger I was fumbling around trying to do this and brought it to a mechanic friend who actually worked at the Fiat dealer at one point. He took the bushings and control arm from me and before I could say anything he had driven in both bushings all the way in, ruining both them and the control arm as the hole became too enlarged as a result. Needless to say that was the last time I asked for his assistance with anything on my car.
SpiderJunkie
Thanks for the reply Sam, I could see easily pushing them in past the stops if someone was using a hydraulic press, using a vice give you a lot better feel as to how far you should go. :mrgreen:
SpiderJunkie
Fenelon Falls, ON
Canada
SpiderJunkie
Which way do the lower control arm inner washers face, it would make sense to me for the cup to be out and cradle the bushing. Mine were installed with the in cup away from the bushing.
thanks Bruce
SpiderJunkie
Fenelon Falls, ON
Canada
SpiderJunkie
What a great forum, found my answer:
http://www.fiatspider.com/f08/viewtopic ... 14&t=26300
Thanks Bruce
SpiderJunkie
Fenelon Falls, ON
Canada
