good day, I need to remove and probably change my oil pan is it thru that I need to lift the motor to get the oil pan out or is there any other ways.
thanks.
Sergio 1977
Oil pan on a 1977 fiat Spider
- sergio1977
- Your car is a: Fiat spider 1977
Fiat 1977
Re: Oil pan on a 1977 fiat Spider
Cutting through the crossmember is another way, but you'll find it easier to lift
Hi Sergio, welcome.
Yes, you will need to raise the motor to remove the oil pan. When you raise it, be sure to not pinch the hoses and wires that run along the firewall (Use a small piece of wood as a spacer between head and firewall).
What is the problem? Gasket leaking? Hit an armadillo?
- sergio1977
Damaged on the oil pan was before me owning it and looks like it’s the gasket that’s leaking tried to tightening it up but still need to be changed and by the way here in Quebec Canada you are bound to hit more an ice block on the road than an armadillo. LOL2500diesel wrote:Hi Sergio, welcome.
Fiat 1977
- sergio1977
how far do I have to lift the motor, do I have to take it out completely.2500diesel wrote:Hi Sergio, welcome.
Fiat 1977
Not sure on a 77, but my oil pan has baffles in it so the oil pump also has to come off before the pan comes out.
Disconnect the exhaust, motor mounts and anything else that prevents upward movement. Jack at the tranny bell housing.
I can remember many years ago ( 1976) I pulled the pan on my 70 and cut a 13 mm wrench in half to get at the bolts on the oil pump. I was young and a tad impatient at times so I thought that was the way to do it.
I thought I remembered trying to loosen the oil pump through the crack between the block and pan. It's been 20 years, but I guess memories like that stick with you.narfire wrote:Not sure on a 77, but my oil pan has baffles in it so the oil pump also has to come off before the pan comes out.
And I still have a cut in half 13mm wrench in my toolbox.
- sergio1977
thank you for the info.2500diesel wrote:I thought I remembered trying to loosen the oil pump through the crack between the block and pan. It's been 20 years, but I guess memories like that stick with you.narfire wrote:Not sure on a 77, but my oil pan has baffles in it so the oil pump also has to come off before the pan comes out.
Fiat 1977
No kidding, just don't ask me what I had for breakfast this morning....2500diesel wrote:It's been 20 years, but I guess memories like that stick with you.
I have that cut wrench around as well. I was given a small set of metric wrenches for my birthday soon after buying the 70,(75)
Still have 95% of the Craftsman wrenches I received, Felt bad about cutting the wrench though...
but I digress...again.
