Trunk Floor Board Template
I am working on a 1980 that I recently picked up. I am looking to get a hold of a Trunk floorboard Template. Does anyone know where I can get one and make my own floor board. Unfortunately the car came without one.
Re: Trunk Floor Board Template
Good luck finding one to borrow.
I need to do this too. I can tell you the floorboard is 2 pieces. I plan on making my own template with paper or cardboard.
Same with carpet except its one piece.
Fred
Lake Norman, NC
1977 Fiat Spider (current project)
1977 Triumph Bonneville 750 (previous project)
1971 Honda CT-70 K0
1972 Honda CT-70 K1
1990 GMC S-15 Jimmy (Daily driver)
Lake Norman, NC
1971 Honda CT-70 K0
1972 Honda CT-70 K1
I don't have a template, but I could take a picture of my original 2pc trunk floorboard that's in my car and post it with some measurements. It's a '79 Spider. Would that help you?
Todd.
Todd.
1988 Mazda RX-7
1979 Fiat Spider 2000
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
Sure. Any help I can get would be appreciated. Thank you.
I have a set I of templates I got years ago form another member here on the forum. I am traveling until August 9th but when I get home I can trace them and send you a set.
Jeff Klein, Aiken, SC
1989 Spider, sold
2008 Mercedes SL65
2008 S600 Mercedes V12
1989 Spider, sold
2008 Mercedes SL65
I am sure somebody out here has one
I was fortunate enough to use my trunk carpet a template
http://forum.fiatspider.com/f08/viewtop ... lit=+trunk
Here is a phenomenal post
Hi Zach Mac,
Let me know when your back and I will send info. I am also away it Italy from Aug 11 to Sept 1 so no hurry. I will work on it when I return anyway.
Thx.
Thx.
If someone can take pics of their truck boards, straight on and with a reference measurement, I will digitize them so people can print them out full scale at staples. I have my own large format printer and I've been googling around for a printable template. I can post them up on my fiat blog for everyone to download.
Actually, it seems as though I have the carpet and one of the wood pieces. Didn't realize it. I still get bits and pieces from the PO now and again. The original wood piece doesn't seem to fit all that nice. Maybe I will design my own using the rug and one piece of wood as a jumping point. If I make digital templates I will post them.
Hey Niagarafiat, I just returned to this post for the first time and found your response,...wish you had PM'ed me! I'll get a pic right away and post it with measurements. Mine are original and are made of dense fiberboard.
Todd.
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
This should help:
That would be 39.5" x 25". Split at 16".
Todd.
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
I just put up a post about how I made a template on my blog. On the right column I put a link for you to download it. Go for it! You can print it using the "tile" setting in your print drive and then tape a ton of paper together, or head down to an office supply store with a large format printer and have them print it out (less than $2 around here). Make sure you tell them to print at 100%.
It should get pretty darn close to fitting. You may need to remove a little material, I recommend printing it, cutting it out and making sure it fits in your trunk. Not sure if every car is completely identical. I need to make a plastic cover for my hoses. You should be able to rig something up on your own.
http://fiatspider.weebly.com/
I make no guarantees that it will be perfect, but it should be a great starting point for anyone without rugs.
COOL! I'm glad you got the pics, Niagarafiat! I sure hope that helps you fabricate a set of trunk floor boards. And with the template download from jimmycakes401, you should have NO PROBLEM making either the boards or a carpet!
I have new carpet (as of about 2004), and I doubt if you'd need a pic, but let me know! My car is obviously in very good shape for it's age, and is nearly all original, so I'd be delighted to provide any pics of the original state, if I can. I need to post this elsewhere so everyone knows,...
Glad you can use the information!
Todd.
Todd.
1988 Mazda RX-7
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
1976 Camaro
1972 VW Superbeetle
1969 Ford F100
1968 Mustang coupe
