I'm looking to buy. Can someone please answer
kristoj
Your car is a: 1982 Fiat Spider 2000 Turbo
Re: I'm looking to buy. Can someone please answer
Post by kristoj »
mdrburchette wrote:I'm afraid I disagree. Although the 82 is fuel injected, the early ones are more classic. Why else would so many people spend so much time and money to make their later models look like the early ones? 8) Really, you should look for the best example and not worry too much about what year it is. They all have their good points and bad (although I can't think of any bad for a 72 :wink: ). Here are a few things you need to look for when buying:
Rust. Check the outside shell for any paint bubbling. Rust starts from the inside and goes out so bubbles means rust through damage. Also get under the car and use a screwdriver to test the floor pans. Also check the shock towers and crossmember to make sure they're solid.
Door hinges. Especially in the later model cars, open the doors and check the upper and lower hinge mount points on the door itself. If they are cracked, they're a bear to have repaired.
seatback frame. Especially on later models, the driver's side seatback can become bent from people leaning over and pulling the top up while sitting in the car. The fix isn't so bad if you can use a welder.
Electrical. Make sure everything works on the car. Nothing's more of a pain than trying to trace and repair wiring that someone else has tried to repair.
Transmission. Make sure the transmission operates smoothly and doesn't jump out of gear or grind. They can get expensive to repair.
Does anyone else have more to add?
I would also look for gear whine or other issues in the rear differential , particularly on '79 and up models as they used a different design. Pinion seals on the front of the diff often leak leading to low fluid and premature failure. It is also imperative that you replace the timing belt immediately after purchasing the car unless there is documented evidence that it has been done within the last several years or 30,000 miles. The good news is that many parts for Spiders run significantly cheaper than most other cars, even with the devaluation of the dollar against the euro. Good luck!
Oh, and I almost forgot -- 1982 is the best year to own :lol:
John
'82 Fiat Spider Turbo
'56 Abarth 750 GT Corsa MM
'59 Lancia Appia GTE Zagato
'70 Moretti Sportiva S2
'12 Abarth 500
'59 MV Agusta 250 Raid
Pictures of my baby!
pope
Post by pope »
There is no doubt that the best year was 1980!!!!!! The only year that you could buy it as a carbed or Fuel injected model.
mbouse
Post by mbouse »
but, not on the same car. You'd have to get two 1980's.... go with the carb'd one. better for making mods to.
pope
Post by pope »
Mike, I rebuilt my car with two fronts welded together (no back end). One has a carb and the other is fuel injected. That way I can decide which one I want to drive. And I never have to back up. :mrgreen:
mbouse
Post by mbouse »
So, do you have a FiiF or a SpiipS or a 2002 ??
inquiring minds could care less.
manoa matt
Post by manoa matt »
Fuel injected cars don't make that deep rumbling throaty hot rod sounds that a carburator car can make. The sounds the car makes are half of the fun, especially when you drop the pedal, that second barrel opens up, and it takes off.
"A hot rod isn't a hot rod untill it sounds like one." (or sports car)
My .02 cents
Matt
mdrburchette
Post by mdrburchette »
You tell 'em Matt! If you really want to sound big and mean, strap a set of IDFs on that sucker and you'll never need a radio. :D
1972 124 Spider (Don)
1971 124 Spider (Juan)
1986 Bertone X19 (Blue)
1978 124 Spider Lemons racer
1974 X19 SCCA racer (Paul)
rlux4
Post by rlux4 »
I feel bad for all you "other than '82" owners. I'm sure all this rationalization is caused by jealousy. Sad to say though, they only made so many '82 and so there's just not enough to go around. Thank God I got mine in time!
Ron
Ron Luxmore
rlux2n2@gmail.com
Jimb
Your car is a: 1985.5 Volumex
Post by Jimb »
So why hasn't this one got more offers? It seem like a descent car.
http://cgi.ebay.com/ebaymotors/Fiat-spi ... enameZWDVW
Leesfer
Post by Leesfer »
Jimb wrote:So why hasn't this one got more offers? It seem like a descent car.
Because it's not an auction item ;)
Ps... Dont pay more than a few thousand for a good fiat spider, 10,000+ is overpriced
ga.spyder
Post by ga.spyder »
I have to agree with Leesfer.That is an awful lot of money for that car!It looks like he is a dealer on a ''fishing'' trip ,hoping someone will make a high offer.My 82 w/ good paint,running great ,no rust ,and not many issues was 4000,and Im sure there are even better deals out there. From my own bad exp. on ebay ,I would make a trip and drive any car before buying. The pix never tell the whole story. You might be able to get a FLU member ,or forum user here to look at a car for you if its way out of your area.We all like to look at cars!!
Good Luck ,Craig
Craig Nelson
Fling It Around Turns !
Jimb
Post by Jimb »
No question it's expensive...and the seller is on a fishing trip.
However, I am surprised the ad didn't get more offers even if they were just in the 5-7k range.
manoa matt
These are a few of my favorites taken from the add:
This car is remarkable in that it does not have a "restored" feel. Rather, it appears correct and preserved---looking much the same as it did more than 25 years ago. ( Just look at the engine bay, all original hoses)
Even if a sound example was located, we doubt you could duplicate what we have in front of us for less than $20,000. This car is only minor details from being a reference example. ( you could do a complete body off, period correct, restoration for less than $20,000)
Current CTM guide places the range for similar cars between $13500-$17,800. ( Funny, all my price guides are $10,000 off.)
Darsella1
Post by Darsella1 »
Alfa's are not nearly as fun! Even a few dual car owners in our club say so!
I would go to a show and look at as many examples of each year as you can. Each person seems to fall in love with a different year for different reasons. For me it will always be the later 81-85 cars.
The only year I know had the most issues is the '79 and unfortunately, they are the most common year.
if you want a stock car to just drive, get an 80 or newer FI model. If you want one to modify, then get a 78 or earlier car. I'd steer clear of the 80 and 79 carb models unless it's very cheap and you want to make some mods and can afford the mods.
