I am also looking for the rubber pieces that go on the back windows (on the chrome), mine have gone missing
Do you mean this? http://www.autoricambi.us/product/RE2-4 ... with-Felt/4uall wrote: I am also looking for the rubber pieces that go on the back windows (on the chrome), mine have gone missing![]()
All of the holes in the doors also had caps or covers; some were taped over.donm wrote:Here's a tip: I replaced all the rubber door trim like you're doing and I was still getting water leaking into the car during heavy rain. I finally figured out where it was coming from. Originally when these cars were built there was a sheet of plastic hanging in the interior of the door, draping down and covering the door access holes. You can see this if you take off the door liner. On my car and I expect a lot of other cars, this liner was removed to gain access to the window crank mechanisim and not replaced. What happens is rain water leaks down past the window seals, passes through the access holes and runs down between the metal door skin and the door liner, leaking into the car. It also warps the cardboard door liners. So I replaced the sheeting and no more leaks.
