I notice two sets of carbs on AR web store,40iDF
What the difference between them? I assume wider throats?
IDF
Re: IDF
I am yes, so the lower cost is the same , just name brand differntSoFlaFiat wrote:Jim, if your are referring to the duel set up, one pair is genuine Weber, the other is the lower cost knock off. Pretty sure they are the same size carbs.
Re: IDF
Yes I'm aware of that, I need another set but I may go bigger, I will see what beek says when the time is right,
And umm, I'm not into trying to save gas
it all about speed and power,
Re: IDF
Jim, I'm at the thinking stage of building another engine and it was mentioned to me that if I use the 2L engine, look for the 44 IDF's. Now I hope the engine guru's here will chime in to confirm as well.
Mark has a short video that compares the 40 and 44 idf's , both the EMPI and Weber carbs mounted on a VW motor when on a dyno.
http://www.youtube.com/watch?v=WP3fOWaaQy4
I remember seeing posts here regarding the hood height and the 2L engine with the IDF's...not sure what the outcome was as I thought the IDF's needed a healthy clearance above for air movement...again engine guru's please....
Chris
Chris
Re: IDF
I will get what best for what I'm getting done, I do have them dcnf, I think that what is is
- Your car is a: 1975 Spider
Re: IDF
the dcnf's will work better for hood clearance. they are a shorter carb
son has 78 spider
son has 78 spider
Re: IDF
But,what better for what we are doing, just askingBEEK wrote:the dcnf's will work better for hood clearance. they are a shorter carb
