Hey Steve, I didn't know how to shrink it down and it figures when I uploaded the original pic it cut off the very side I was trying to illustrate. I'm glad I mentioned it and you clicked on the pic and could see a better shot of the whole engine bay... If you can post a pick up of the manifold you have so I can see it first hand if you don't mind and tell me where you were able to find it as that was a car that was never imported here in the States and if you don't mind what did you pay for it? I'm going to include a few pics of the idea I had on the exhaust side of the equation. I thought about using a 4 -1 manifold and hack off the Fiat donut flange and weld on a Tial V-Band flange.
Here's my thought process on choosing this style turbine exhaust housing: first, the diameters are very, very close and to make a perfect fit would only require very little blending to keep a really nice flow and no big pressure changes and reversion going from that smaller round hole (fiat side) to a larger squared T- 4 style flange. Second, The Tial exhaust housing/flange has been proven time and time again on the dyno to improve spool/lag response over its equal size turbine exhaust housing in a T-4 and is good for a few horsepower as well. Not that these cars will ever see the kind of power I'm used to making in other applications I've worked on over the years but its nice stuff with practical uses which can be applied to even smaller projects
Third, it will clean up the engine bay quite a bit and makes for easier turbo placement since it has a much smaller footprint from its T-4 brethren and can be clocked to any position you need unlike a traditional 4 bolt setup on almost all standard turbos.
Now I know some people will say that you can't weld to cast... You can, it's just not usually done because if not done properly it will just snap off. You have to really get the cast part you will be welding to really, really hot first before you even think about welding to and then it would always be a good idea to brace the weight to help with the stress and strain that a 20lb turbo will be applying to the welded area. Worst case scenario we just build a nice tubular manifold and call it quits. If there's enough demand for it I may put up some money and contact a fabricator I know and have a run made...
Tial V-Band flange
Complete turbo
This is a tubular exhaust manifold off a Miata w/ a Garrett T-28 turbo but using a Tial exhaust housing instead of the standard T-4 square flange housing
