Loosing coolant
Loosing coolant
From the first day That I brought it home my car looses about a quart of coolant every 500 miles. I have no leaks and no sign of a bad head gasket. Not even condesation out of the tail pipe. It never runs hot because I stay on top of this. Is this normal ?
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
Re: Loosing coolant
this is not normal. If you are not loosing it thru the head gasket, you've got a leak.
Re: Loosing coolant
Thanks, I will continue to look for leaks and maybe pull the plugs and take a closer look.
Dennis Modisette
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
1972 124 Spider
2003 Chevrolet Z71
2007 GMC Yucon
- Your car is a: 1979 Fiat 124 Spider
Re: Loosing coolant
You can check for exhaust in your antifreeze with:
http://www.napaonline.com/Catalog/Catal ... 0006398563
--John
2007 Audi A4
2007 Audi A4
Re: Loosing coolant
check for white/greenish deposits on the undersde of conections between rubber hoses and other elements in engine compartment and on cabin heater. it's likely that there is a leak but fluid evaporates because of the heat of the engine before you get to notice it
- tartan18
Re: Loosing coolant
As djape1977 said, I had a small coolant leak but couldn't figure out the source because nothing was dripping on my garage floor. I finally spotted the location of the leak -- lower nut that connects the heater pipe to the water pump was loose. The coolant would evaporate before hitting the floor. I didn't notice it because my upper alternator bracket is polished aluminum so it didn't show the telltale white deposits.
Jim MacKenzie
1975 Fiat Spider
1975 Fiat Spider
Re: Loosing coolant
there you go, you owe me a beer.
cheers!
cheers!
